Do you use rubber cement with the plugs? It really helps to make the plug go in much easier aside from helping it seal and adhere.
I don't think I would recommend rubber cement, as I would think it would damage the weather seal if you ever had to take it apart. Silicone grease or dielectric grease would be a better choice, IMO.Do you use rubber cement with the plugs? It really helps to make the plug go in much easier aside from helping it seal and adhere.
I was referring to the tire plug, dry installing the plug is much harder without it and you struggle to push it in without the lubrication of the adhesive. I’ve broken the plastic handle pushing a plug in an very fortunately didn’t shove the metal shaft through my palm.I don't think I would recommend rubber cement, as I would think it would damage the weather seal if you ever had to take it apart. Silicone grease or dielectric grease would be a better choice, IMO.
Thanks for watching. It is a 2012. Not sure what gen that is...Looks like a gen 2 Frontier by the dash and the rear disc brakes.
Nah, just stuffed it all in. If it lasts a year from today I will be good. It costs 10 dollars and takes like 15 minutes to replace...Do you use rubber cement with the plugs? It really helps to make the plug go in much easier aside from helping it seal and adhere.
Sorry I misunderstood you! No, I do not use rubber cement, but your suggestion is interesting. Specifically your tip on making the plug easier to put in!I was referring to the tire plug, dry I stalking the plug is much harder without it and you struggle to push it in without the lubrication of the adhesive. I’ve broken the plastic handle pushing a plug in an very fortunately didn’t shove the metal shaft through my palm.
I think I might have a small tube of rubber cement somewhere. I will try that next time! Thanks for the tip!Most kits I have bought come with the tube of adhesive and the last ont i I stalked refused to go in so I tried using it and went in much easier. I do want to buy a pro set that has aluminum handles on the reamer and the plug installer too. The bonus would be a blow molded case to keep it orderly.
