I measured today on my pro4, and there seems to be around 1” difference front to rear. Maybe 1.25. Will the 1.5” spacers be fine? I don’t want to add them and have the front higher than the rear
Yep, my p4x measures 1.25" higher in back. If you do 1.5" in the front and 1" in the rear it will only be .75" higher in back. (or 2" fron, 1.5" rear).I measured today on my pro4, and there seems to be around 1” difference front to rear. Maybe 1.25. Will the 1.5” spacers be fine? I don’t want to add them and have the front higher than the rear
Just wanting to level out the truck. I’d love to lift it 3+” but don’t have the cash to do that or go bigger tires. So for what I’ll do, stock height is fine. Just want it levelAlways nice to know , what you are trying to accomplish? I am assuming , a little but if lift for looks.
I’m a little confused, are you saying the pro4x won’t level with the 1.5”?The 1.5" PRG spacer is a good option. Do it.
You don't run into coil bucket contact issues.
Forget if you are PRO4x. but won't run into shock crush issues with stock bump stop. = MAx travel
You don't need extended top hat studs. Just pull the shock assembly out, bolt on the spacer and bolt the shock back into the truck.
The PRG "1.5" spacer lifts ~1.5" it is about 3/4" thick.
You should still get cam bolts. Adjusted per instructions in the sticky. Then take it to an alignment shop post lift.
Frontier/Xterra 1.5 inch Lift Spacers | PRGProducts.Com
Billet 1.5" lift spacers for all 2005+ Frontier and Xterra models. Easy to install, does not require taller bumpstops like our other spacer kits. These kits are especially good on the Pro4x models as there is much less alignment or noise potential issues as well as a stock ride vs taller spacer...www.prgproducts.com
How the heck did you read that? Read my first sentence again.I’m a little confused, are you saying the pro4x won’t level with the 1.5”?
I think it was the 3rd sentence that confused him (and me). Might try full sentences instead of Cliff notes for us more "challenged" people. Lmao.How the heck did you read that? Read my first sentence again.
If you are questioning if the 1.25 of your measured height difference and the 1.5 of said lift, is going to make an unleveled truck; it does work out that perfectly numbers wise.
Hard to be perfectly level. Tire to top of fender arch measurment level is not always the same as bubble level on the truck bed rail level. Parking on a slightly pitched surface can easily change your measurement half an inch. Full tank of gas. Fat passenger. Condition of front and rear springs. All can have an effect on "level".
A 1.5 " lift spacer, that measures only about 0.75" is your best bet at level.
Do I need the cam bolts with this kit?We might be a little late to the game here but if you're looking for leveling kits our rckilla is on sale up to Black Friday @Jonathan M
Alldogs Offroad RCKilla Coil Spring & AAL Lift Kit for 2nd Gen Nissan Frontier
www.alldogsoffroad.com
This'll lift you 2" in the front and 1.5" in the rear. It looks great with stock tires, too.
If you don't have adjustable cam bolts already we would recommend it.Do I need the cam bolts with this kit?
My local shop wont install this, the reason : They dont understand how Im putting longer springs on my factory struts... They're telling me the struts wont be long enough to work with these springs?If you don't have adjustable cam bolts already we would recommend it.
That's an odd one to hear. We install these without issue on stock struts and Bilstein 5100's. I'm sure they've installed Old Man Emu coils on Bilstein 5100 struts for a Tacoma or 4Runner. Same concept.My local shop wont install this, the reason : They dont understand how Im putting longer springs on my factory struts... They're telling me the struts wont be long enough to work with these springs?
Find a better shop that knows how to work on aftermarket suspension and knows what they're doing.My local shop wont install this, the reason : They dont understand how Im putting longer springs on my factory struts... They're telling me the struts wont be long enough to work with these springs?
