1 - 9 of 9 Posts
Figured I would share another 1/4" spacer option that I recently used for my lift install. This should work for any of the gen 2 Frontiers. The spacer itself is a polyurethane unit made for various Toyota models. However, a simple modification can be made to allow it to work for the Frontier strut assembly.
The inner and outer diameters of the spacer match up to the Frontier assembly perfectly. Measurements below for those who are curious:
The only issue is that the notches for the strut bolts are spaced equidistant whereas 2 of the Frontier strut bolts are positioned closer together:
This can be fixed with a simple modification using a dremel or similar tool. Since the spacer is made out of polyurethane, it takes little effort to expand the bolt notches.
Before vs after:
On the top hat:
Overall, I'm happy with how it turned out. I wanted the 1/4" spacer to supplement bilstein 5100's set at 1.5" lift to effectively provide 2" of total lift, and it did so. I originally was going with a spacer developed specifically for the Frontier, but it was backordered so I took a chance on this.
Link to where I bought these below. They were about $28 shipped.
https://wheelersoffroad.com/i-30063265-1-4-thick-single-strut-top-plate-spacer-for-95-04-tacoma-96-02-4runner-99-06-tundra-whe-tps14-or-wor-tps14a.html
Sent from my SM-G930V using Tapatalk
Cool! Always down for more options. Let us know if there are any long term issues.
Before vs after:
On the top hat:
Thanks for posting. I want to do something similar. Have you had any coil bucket contact running the 5100's at 1.5" with an extra 1/2" of lift from the spacer?
Curious on that ^ as well.
And how is the ride with the 1.5 Bilstein setting plus 1/2” (1/4”) spacer? I plan on going this route for the front as well.
I used this same poly spacer with 5100s (set at lowest setting/no lift) with Alldogs Offroad lift coils. 2" total lift in the front. The ride is great.
313876
Looks great! Does that mean the All Dogs coils are longer than stock?
Yes, the ADO coil is a little longer and little stiffer than stock And will give you 1.5“-2“ lift, depending whether you’re 4wd or 2wd. They recommend only using it on the lowest setting on the 5100. Really happy with the setup.
1 - 9 of 9 Posts
