I need to do the 30K service on my truck and I need to know what things need to be done. Thanks for your help ahead of time.
Here is the link to the owners manuals and service manuals from Courtesy Nissan: nissan owners manual download
Service manuals are at the bottom. Per that, for 2008, here is the info:
PREMIUM MAINTENANCE
Replace engine oil and filter
Lubricate all locks/hinges
Replace automatic transmission/CVT fluid
Replace differential oil 1
Replace engine air filter
Replace engine coolant/flush system
Replace engine drive belts
Replace in-cabin microfilter 2
Replace manual transmission oil
Replace radiator cap
Replace transfer case oil (4WD/AWD)
Replace wiper blades
Rotate tires (except 350Z)
Optional: flush automatic transmission (flush with ATF)
Inspect the following:
__ All lights
__ eCVT fluid (HEV) 4,5
__ Axle & suspension parts
__ Brake lines & cables
__ Brake pads, rotors, drums & linings
__ Cruise control vacuum hoses
__ Drive shaft boots 3
__ Exhaust system
__ Front suspension ball joints
__ Fuel lines/connections
__ Fuel tank vapor vent system hoses
__ Headlights/adjust if necessary
__ Propeller shaft (4WD/AWD)
__ Steering gear and linkage
__ Steering linkage ball joints
SCHEDULE 1 AND 2 MAINTENANCE
__ Automatic transmission fluid 4
__ CVT fluid (Altima, Altima Coupe, Maxima, Rogue,Sentra and Versa)
__ Differential oil 1,4
__ Exhaust system
__ Manual transmission oil 4
__ Transfer case oil (4WD/AWD) 4
I also need to get the 30k service. Is it all really necessary or is some of that not really needed? Any opinion would be appreciated. Thanks
The majority is general/common automotive up-keep.. esp. if you wanna keep an extended warranty intact.
bring some KY when you ask/do a full A/T "S-matic" flush tho'.
