Year:2007
Make:Nissan
Model:Frontier Crew Cab
Mileage:171000 M
Transmission:Automatic
Engine:4.0 V6
Trim:LE
PRICE DROP TO $13,000!
Hey all,
With a baby on the way and some life changes, it's time to list my Frontier for sale.
It's a 2007 CC 4X4 short bed LE. Currently it has 171,xxx miles on it and it will go up as it is my daily driver.
Tan leather, sunroof, heated seats, heated mirrors, dual power front seats.
OEM/Maintenance
Both front door checks replaced with OE parts
OE transmission pan, gasket, and fluid flush and refill with Nissan OE fluid
Both Valve cover gaskets and passenger side valve cover replaced w/ new OE PCV
OE belt tensioner and new serpentine belt
Updated OE IPDM replay
Exhaust gaskets on primary and secondary cats replaced
New OE clock spring
Dorman radiator mount bushings
Transfer case output shaft seal and boot replaced with OE seal and boot
OE spark plugs
2 degree timing advance
Dorman metal heater core inlet and outlet connections
Front diff, transfer case, and rear diff fluid replaced
Brand new OEM leather steering wheel
New battery installed
New OE battery fuse terminal
Aftermarket/Mods
Nisstec Mk.II Extended Travel coilovers
All Dogs Offroad Upper Control Arms
Sway bar delete
Camber/Caster bolts
RC N3 extended rear shocks
RC 1.5” lift shackles
P4X engine and transfer case skids, OE metal radiator skid
Powerstop Z36 front brake kit with rotors and pads
Rago Designs ditch light brackets
RC spot lights, RC flood lights with fog light bracket kit, MTC rear amber lights
AOB OE style/fit switches for lighting
Pioneer double DIN radio with back up camera and streaming audio
Pathfinder “shorty” leather rear headrests
Double front tow hooks
Tow package hitch with 7 and 4 pin plugs relocated to rear tag area
17” Motegi Trailight wheels with Falken Wildpeaks 32x10.50
Hayden transmission cooler with radiator bypass
Swing out bed tool box
Prinsu Roof Rack
Smartliner molded front and rear floor liners
Rear axle vent mod to passenger taillight
Center console CCW magnet mount
Black housing headlights w/ LED bulbs
Satin black grill, front emblem, and rear emblem
Stubby antenna
Billet battery tie down for larger battery
I also have the OE 4 spoke wheel with tires, OE rear headrest, OE radio, OE roof rack, and a set of OE fitment LED fog lights to go with the sale.
I would consider an Xterra on trade similar sized SUV.
My build thread can be found here with multiple photos and date stamps:
Photo before Prinsu rack and RC fog lights install:
