Good morning,
I have 2006 Frontier 4x4 and having some issues below and I hope someone kindly advises me where to look or check.
1. ABS light is ON
2. 4WD did not work. When I drive on 2WD I can see the graphic indicator on left is showing my RWD but when I switch to 4WD (High or Low), the graphic blink once or twice then disappear so no graphic showed but the 4WD light is on (see picture) the top.
Any advice will be greatly appreciated
310583
310582
Good morning,
1. ABS light is ON
You need to have the truck scanned for codes. Probably have a wheel sensor out.
that was what I thought as I read the post. Id start by inspecting each wheel sensor. Sometime it is a torn wire. Some of the generic ODBII scaners do not do ABS codes.
