From the FSM for an '07
REMOVAL
CAUTION:
-Do not attempt to repair or replace damaged direct-connect SRS component connectors. If a driver air bag direct-connect harness connector is damaged, the spiral cable must be replaced.
-Before servicing the SRS, turn ignition switch OFF, disconnect both battery cables and wait at least 3 minutes.
-When servicing the SRS, do not work from directly in front of air bag module.
1. Disconnect both the negative and positive battery cables, then wait at least 3 minutes.
2. Locate retaining clip access hole and insert suitable 4mm - 6mm blunt tool.
CAUTION:
Do not use sharp edged objects such as screwdrivers to release driver air bag module from steering wheel, SRS components may be unintentionally damaged.
3. Press upward (toward center of steering wheel) on retaining clip until driver air bag module is released from steering wheel.
4. Lift the driver air bag module from the steering wheel.
5. Disconnect the driver air bag module and horn connectors, then remove the driver air bag module.
