I'm hoping someone can tell me if this is 'normal'. There are one or two mountain passes on my daily commute home on the interstate (65MPH speed limit). Unless I hit them going 70-75, the engine bogs too much for my liking (and I don't usually drive that fast anyway). SO, I like to turn off OD before I hit these sections.
In one particular section, there's a slight downhill prior that I try to coast down to around 60-62MPH and turn off OD. However, more often than not, I get a very loud CLUNK from the transmission when I do so. The only time it *doesn't*, is if I'm 100% coasting, foot off the pedal, doing 55MPH (cars backing up behind me, because most are racing to make the hill).
Today for instance, on a flat section, I was doing 60MPH, ONLY enough pedal to maintain speed, and I still get this clunk. I never get this noise/jolt when turning OD on.
I expect to get a bit of a blip in RPM coming out of OD, but this is more than that. It's not like I'm mashing the pedal/racing when I do this.
So do any of you folks shift in and out of OD on the interstate? What's your experience? Truck has 71,000, A/T has 20,000 (replaced under warranty for prior owner - radiator broke down, destroyed the AT).
Thanks for reading!
Thanks for reading!
