1 - 4 of 4 Posts
I have grease all over the left rear caliper, inboard side of the rotor, parking break shoes ect. I turned the wheels and there is no noise to indicate a bad wheel bearing so I think it's just the seal. Has anyone else had this problem, if so was it more than the seal? Has anyone changed this seal? Do I have to remove the bearings to get to the seal or is the seal located in front of the bearing. Basicially, can anyone give me directions on how to replace the seal?
Thanks in advance for your expert advice.
are you sure that it isn't a leaking caliper or hose line to the caliper?
typical... my 05 has had both sides re-done... Do the vent mod asap! From what I understand the seals are a PIA to change.
1 - 4 of 4 Posts
