05 CC 4x4 v6 160K miles
Had racket from timing cover.Replaced tensioners etc now the truck cranks but won't start.
EVERYTHING is hooked up but there is no CHECK ENG light when key is on and OBD keeps saying NO CONNECTION.
UPDATE:
TWO different OBD's (w/two different technicians) read NO CONNECTION.
Are these trucks given to sudden ECU death?
Is Nissan service in my future?
2016 Frontier SV 4x4 Crew Cab
well he said everything is hooked up, but if that was the case then i'd suspect an obd2 error of 'no connection' would mean otherwise... like it can't reach the ECU. is it possible the ECU got damaged I wonder. doesn't make sense, if doing just engine work you'd probably only unhook the battery right? strange.
keep us posted...
