2007 Nissan Frontier NISMO CC
are 13-up different and not compatible? I'm seeing the 05-12 part number has been discontinued.
Thanks for the help!
I don't know the answer to your question but there are a lot of used ones on EBay.
There is a small "fitting" connection inside. I found that it was broken, in my driver side visor. I tried to glue it, without success. I found a small thick O ring in a plumbing oring pack that fit tightly enough to keep the visor from flopping. It is good as long as it stays in the keeper bracket. I'm not sure how long it would last if the visor was moved to block the side window. But, 90% of my problem was straight on sun, so I'm happy with the fix. Nissan should have a kit for this fix, but you have to buy an entire visor, which sucks. You might buy the cheapest visor on ebay, just to get the part you need.
assuming the used ones will be floppy like my current one is.
Yeah, it's too bad there's no way to ask sellers a question, no buyer protection or return policies.
Kinda weird that there's plenty of new ones available for 1st Gens.
