Hello 1st gen peps i have an 04 frontier 4x4 king cab super charged 3.3 my knock sensor went out after replacing the sensor it started once, since the knock sensor i have replaced the injectors, fuel regulator, fuel filter, fuel pump, crankshaft sensor, coil, icm, cap, roter, plugs, wires and idle control valve, it will not start WTF?
That's a GREAT example of "throwing parts at a problem" !!!
As far as throwing parts at it, this truck was neglected and im going to be traveling soon and would rather fix the stuff now then out on the road some where. Thank you for the input its still a great truck
I have found the problem, i have a short in my injector wiring harness
Thanks for posting the solution, many neglect to do that.
