1 - 8 of 8 Posts
Hi all,
I just want to confirm that the rear diff in my 04 Frontier 4x4 w/ LSD is indeed 2.8 liters (about 3 quarts). My fill plug is seized and stripped. so i ended up blindly filling the diff through the breather vent hole. Only 1qt of oil came out when i went to drain it. :( Hopefully nothing is damaged. While i was at it i performed the fuel filter breather mod since the old beather was rusted and clogged.
Yep, just did mine. Right at 3. My front filler plug is stuck, and on the verge of being striped. I only have about 250lbs of torque on my gun. Size matters. LOL
great thank you!
2017 Pro-4X w/Luxury Package
Can you get the drain and fill plugs out, and replace them with new ones wrapped in Teflon tape so they won't get stuck again?
One can get a new fill plug from Nissan; they are only around $3...about $8 if you need the drain plug. If the fill plug is stripped, there are a couple of things you can do to remove it (make sure you have a new one to replace it with after you remove it). You can take an air hammer with a chisel bit and use it against the edge of the drain plug to cut a notch into the drain plug and then drive the plug counter-clockwise until it breaks loose and can be removed by more conventional means. If it's really tight, you can take a long piece of steel and weld it to the plug, itself, and then turn the piece of steel to remove the plug.
thanks. I'm actually thinking about leaving it for now since I already have it filled with new oil. I originally tried impacting it off which led to rounded out the bolt. Then I tried torching it and using a big vise grip and jack to turn the vise grip and no luck!. The truck has 180k on it, so if I can get another 100k out of it I would be happy. Luckily I had no issues with the front diff.
X2.
Also I'm a big fan of PB Blaster. Soak that thing up good, multiple times (as in over the course of several days), while tapping on it and it may easily come out.
I never recommend using an impact gun on a differential or transfer case drain or fill plug. It seems like a good idea but most of the time it just messes up the plug. I always use a breaker bar.
1 - 8 of 8 Posts
