Steady Engine light but no code - Nissan Frontier Forum
 4Likes
post #1 of 39 (permalink) Old 03-12-2019, 06:39 PM Thread Starter
Quoted: 6 Post(s)
I have a 2014 Nissan Frontier SV 4X4 with just under 30K miles and have never had an issue with it.
The engine light has now come on and is steady. Everything seems to be fine. All instruments are normal. No engine noises or misfires.
I've verified that the gas cap is in correctly.
I plugged my OBD II code reader in and there are no codes showing. I've since driven a few local trips, with stops and starts... hoping that the whatever caused the engine light to come on would reset and turn off the engine light... but so far it hasn't.
I do all my own general maintenance and have a good working knowledge of engines and I don't abuse my cars and trucks.
I really don't want to go to the dealer... and want to avoid that... if I can.
Any suggestions on how to proceed?
leedav1s is offline
post #2 of 39 (permalink) Old 03-12-2019, 06:50 PM
butterman2473's Avatar
Quoted: 144 Post(s)
Have you tried to get the code manually?
2004 Nissan Frontier XE KC KA24DE
butterman2473 is offline
post #3 of 39 (permalink) Old 03-12-2019, 06:56 PM Thread Starter
Quoted: 6 Post(s)
Is that not what I was doing when I plugged in my OBDII code reader?
leedav1s is offline
post #4 of 39 (permalink) Old 03-12-2019, 07:02 PM
Quoted: 144 Post(s)
In car ECM Diagnostics/ECM Reset procedure:
1) Sit in the driver's seat.
2) Turn the ignition key to the ON position and wait three seconds. (Do not start the car.)
3) Fully depress and release the accelerator pedal five times in less than five seconds.
4) Wait exactly seven seconds. Fully depress the accelerator pedal for ten seconds until the SES light flashes.
5) Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.
Long flashes (0.6 seconds) indicate the first digit of the code; count the blinks one through nine and write down the first digit. (Ten blinks indicates a zero.)
The next three digits follow in turn in the same fashion except with faster blinks (0.3 second) and a 1.0-second pause between digits.
The ECM code repeats intself until you turn the ignition key to the OFF position, at which point the ECM resets itself to standard get-in-and-drive-the-car mode.
Additionally, if you get four blinks of ten (0000), the ECM is indicating no malfunction.
You can clear the code (and the annoying SES light) by holding down the accelerator pedal for more than 10 seconds while the SES light is blinking. When you release the pedal, the ECM erases the trouble code(s).
The Following User Says Thank You to butterman2473 For This Useful Post:
FitzIngarage (03-13-2019)
post #5 of 39 (permalink) Old 03-12-2019, 07:23 PM
RobFrisco415's Avatar
Quoted: 251 Post(s)
@butterman2473 THIS!!!
butterman2473 likes this.
~~2016 Frontier CC Pro 4x w/ Lux~~
-White Knuckle DOM Sliders
-Diode Dynamics LED's (interior,bed,reverse)
-Shrockworks rear bumper w/Rigid LED's
& backup sensors
RobFrisco415 is offline
The Following User Says Thank You to RobFrisco415 For This Useful Post:
butterman2473 (03-12-2019)
post #6 of 39 (permalink) Old 03-12-2019, 07:42 PM Thread Starter
Quoted: 6 Post(s)
I didn't know about that way of accessing the codes. Thanks!
After doing what you advised...
I got a 0128 code which indicates a Coolant Thermostat Below Temp.
I did notice when driving that the coolant temperature indicated seemed lower than normal... but it has been cold out... so didn't I didn't link that to my engine light coming on.
My assumption now is... that I my thermostat is probably stuck open and should be replaced, which is something that I can do.
Sound good?
leedav1s is offline
post #7 of 39 (permalink) Old 03-12-2019, 07:57 PM
Quoted: 144 Post(s)
You're welcome. Only one way to find out for sure.
The real question is....What's wrong with your OBDII reader?
Last edited by butterman2473; 03-12-2019 at 08:00 PM. Reason: Automerged Doublepost
post #8 of 39 (permalink) Old 03-12-2019, 08:03 PM
NissanFrontierPro4x's Avatar
Quoted: 166 Post(s)
seems odd for a thermostat to go out that soon.
2017 Glacier White Nissan Frontier Pro4x CC V6 6speed Manual
NissanFrontierPro4x is offline
post #9 of 39 (permalink) Old 03-12-2019, 08:35 PM Thread Starter
Quoted: 6 Post(s)
I'm sure that will be it... I'll replace the thermostat tomorrow and if it doesn't reset the code and turn off the SES.. I'll clear the code myself.
Again... I really appreciate your help and I learned something new.
Any idea of why my OBDII code reader didn't give me this code when I plugged it in?
leedav1s is offline
post #10 of 39 (permalink) Old 03-12-2019, 09:27 PM
Quoted: 144 Post(s)
I personally would have cleared the code right after reading it and see if it pops up again before replacing anything.
Similar Threads
Check Engine Light. Code P0463 Sand General Discussion 6 10-10-2018 05:00 PM
Unusual Engine Code - P00D2 Wintermute General Discussion 8 09-28-2018 07:06 PM
Please help with a service engine light problem (Long Post) Sephicien General Discussion 13 07-27-2018 06:48 AM
Check Engine Light is on - Code#: P0335 mariozavala New Member Introductions 1 06-16-2016 11:30 AM
EVAP canister "Service Engine Soon" light triggered by brother in law MrRedbeardman General Discussion 2 06-29-2015 11:41 AM
