keyless entry ? - Nissan Frontier Forum
 8Likes
post #1 of 23 (permalink) Old 03-07-2019, 07:38 PM Thread Starter
Quoted: 3 Post(s)
keyless entry ?
not sure if my 05 frontier had keyless entry.
it came with one key.
anyway to find out ? was it stock ? can I get a fob programmed if it keyless ?
thanks
pawlingfrontier is offline
post #2 of 23 (permalink) Old 03-07-2019, 07:47 PM
JDwoodworker92's Avatar
Quoted: 23 Post(s)
I know my 05 LE was keyless. What trim level is yours?
Sent from my SM-J737VPP using Tapatalk
JDwoodworker92 is offline
post #3 of 23 (permalink) Old 03-08-2019, 12:52 AM
butterman2473's Avatar
Quoted: 144 Post(s)
I think a dealership may be able to tell you by looking up your VIN #.
2004 Nissan Frontier XE KC KA24DE
butterman2473 is offline
post #4 of 23 (permalink) Old 03-08-2019, 03:12 PM
phatB's Avatar
Quoted: 227 Post(s)
if it is keyless yeah you can get a fob for cheap and program it.
shift_RUSH and shift_RUSH like this.
phatB is offline
post #5 of 23 (permalink) Old 03-08-2019, 07:33 PM Thread Starter
Quoted: 3 Post(s)
how can I tell without going to the stealership ?
i have the vin # obviously
its a 2005 SE king cab
post #6 of 23 (permalink) Old 03-08-2019, 08:18 PM
mxtreme30's Avatar
Quoted: 77 Post(s)
Probably the easiest way is to try the fob program sequence. If I remember right you need all doors closed then insert and remove ignition key 6 - 10 times within 10 seconds (dont rush it) then turn key to either acc or on and hazard lights should flash meaning that fob is ready to be programmed. Cant remember exact sequence so someone correct me or Google fob programming for frontier and try it. Hope it helps.
P.S - you dont need the fob to see if truck is set up with keyless. This is how I tested mine and after hazards flashed I just turned ignition off then went online to buy some fobs.
2018 PRO-4X CC in glacier white
AVS vent visors
AVS aeroskin bug guard
Rough Country step bars
Spectre performance filter in stock box
1" front strut spacer
TBC.....
mxtreme30 is offline
post #7 of 23 (permalink) Old 03-09-2019, 08:21 PM
FitzIngarage's Avatar
Quoted: 148 Post(s)
I had to buy the optional Power Package on my 2006 SE to get Remote Keyless Entry. The Package also brought Power Windows, Power Door Locks and Power Outside Mirrors. Based on my '06 brochure, if you own an XE or SE and don't see the Power Package's other features in your truck, you probably don't have keyless entry unless the '05s were different than the '06s.
JDwoodworker92's LE was the upscale trim that had keyless entry standard along with many other nice features. The Nismo too had keyless entry standard at the time.
JDwoodworker92 likes this.
2006 SE CC 4x2 6-Speed 4.0L w/Power Package & ABLS, Red Brawn, Nissan Step Rails, Hood Protector and Worn Out OE Soft Tonneau, Clarion CX501, Stock Speakers, Pioneer TS-T110 Tweeters and LED Reverse Lights
FitzIngarage is offline
post #8 of 23 (permalink) Old 03-09-2019, 09:00 PM
Quoted: 91 Post(s)
Do you have a lock cylinder on the passenger door?
Yes = no keyless
No = keyless.
That is typical for the past 20 years. There are 2 ways into the vehicle. If no keyless and the driver's door lock goes bad, you can get in with the passenger side. But to save money there is no passenger side lock when there is keyless entry. One of the odd cases where betting the cheaper trim level gets you more hardware.
V8 man is offline
The Following User Says Thank You to V8 man For This Useful Post:
FitzIngarage (03-10-2019)
post #9 of 23 (permalink) Old 03-09-2019, 10:14 PM
Quoted: 144 Post(s)
A phone call to the dealership would suffice.
But you should try what @mxtreme30 suggested.
post #10 of 23 (permalink) Old 03-09-2019, 10:17 PM Thread Starter
Quoted: 3 Post(s)
no lock on the passenger door !!
just ordered my FOBS !!!!
pumped
The Following User Says Thank You to pawlingfrontier For This Useful Post:
Similar Threads
Keyless Entry Quit Working BradyInConway General Discussion 5 07-04-2018 04:50 PM
Keyless entry delay Matao87 General Discussion 1 12-29-2017 11:05 PM
adding keyless entry anesthesiachris DIY - Do It Yourself / Tech Tips 0 01-08-2017 06:20 AM
WTB: Keyless entry pad sfujimoto123 Parts 2 11-11-2015 06:52 PM
Keyless Entry Pad & Light Pod Raffle for familiy with Leukemia TruckIt General Discussion 0 12-15-2014 10:48 PM
