Interstate AGM battery? - Nissan Frontier Forum
 2Likes
post #1 of 32 (permalink) Old 04-13-2019, 03:17 PM Thread Starter
Quoted: 3 Post(s)
I am fed up with Optima. My first one was almost 8 yrs old when I sold the truck it was in, still working well and never failed to start the engine. The following ones, in two different vehicles including my ‘05 Frontier, had shorter lifespans. Got one more that lasted over 7 yrs, but everything else lasted only between 2 and 3.5 yrs.
This latest one does not hold a charge, and I am looking at other AGM batteries. I live at least 4 to 5 hrs drive from the nearest larger city (if you consider Albuquerque large), so vendors are, shall we say, limited.
Someone told me that Interstate has a new AGM battery. Interstate supposedly makes one that will fit the truck.
Has anybody used this battery?
The truck is hooked to Optima’s smart charger, D1200 model, and it keeps saying it is 100% at only 12.3 V. Even when I disconnected the battery from the truck and charged the battery for 68 hrs to allegedly 100%, the voltage dropped down to around 12.3V in only 5 hrs of sitting in the garage, still disconnected from the vehicle’s cables.
'05 KC NISMO 4x4 6-spd "home away from home"
midnightsun is offline
post #2 of 32 (permalink) Old 04-13-2019, 03:51 PM
Bamps's Avatar
Quoted: 146 Post(s)
When optima first came out years ago, I think they were built in the US and then they switched the manufactering to China. Also, interstate is assembled in the US but utilizes parts from everywhere else. If you want a good battery, get an “intimidator”
2013 Frontier CC Pro-4X
Auto trans
1aauto tow mirrors
Pioneer MVH 2400NEX head unit
aFe drop in air filter
Nisstec Radflo OE Length Ultimate lift kit
Nisstec UCA and 1” top plate
3 leaf AC AAL rear
Hankook ATM LT285/75 R16 (load range E)
Flowmaster 40 series muffler
Bamps is offline
post #3 of 32 (permalink) Old 04-13-2019, 05:12 PM
Skibane's Avatar
Quoted: 370 Post(s)
I'm pretty sure a lot of their batteries are now made in Mexico - some of which are rebranded from other manufacturers.
IMO, Odyssey is the best battery on the market - period.
shift_RUSH likes this.
2012 Super Black Crew Cab SV 2WD, Shrockworks bumpers, sliders & skids; Retrax Pro bed cover, Hypertech Max Energy Power Programmer, Yaesu FT-7900R 2m/70cm ham radio, Joying Dual-DIN Android head unit, Katana LED headlamp bulbs, Morimoto & RUN-D LED driving lights, Diode Dynamics LED exterior bulbs
Skibane is offline
The Following 4 Users Say Thank You to Skibane For This Useful Post:
9balllrook (04-14-2019), Bamps (04-13-2019), whistler (04-14-2019), Zero Six LE (04-17-2019)
post #4 of 32 (permalink) Old 04-13-2019, 07:55 PM
Bamps's Avatar
Quoted: 146 Post(s)
You’re correct! Made in Monterrey, Mexico.
Auto trans
1aauto tow mirrors
3 leaf AC AAL rear
Bamps is offline
post #5 of 32 (permalink) Old 04-13-2019, 08:25 PM
whistler's Avatar
Quoted: 1078 Post(s)
I need batteries. Yes I would go to Odyssey battieris but my mounts are for Optimas. If they would fit, that is what I would buy.
whistler is online now
Bamps (04-13-2019)
post #6 of 32 (permalink) Old 04-14-2019, 10:19 AM
mtyler11's Avatar
Quoted: 439 Post(s)
Any Group 35 or 24F will fit. The 24F is slightly larger and more CA/CCA
- - Illegitimi non carborundum - -
- - 2014 SV 4x4 V6 Auto - - F.O.R.C.E. - - ExploringNH.com
-build thread- stomper
[gone] 76 GMC Sierra 4x4 RCSB -383 v8, SM465, 3.73:1, TT rear, Dana44 & GM12bolt c-clip converted
[gone] 85 RX-7 5spd
[gone] 79 F-100 2wd
mtyler11 is offline
The Following User Says Thank You to mtyler11 For This Useful Post:
whistler (04-15-2019)
post #7 of 32 (permalink) Old 04-14-2019, 10:31 AM
Skibane's Avatar
Quoted: 370 Post(s)
^You can go considerably larger than Group 24F, particularly if you don't mind lengthening the battery cables.
I currently
have a Group 31 in mine
Optima's spiral-plate design is lame - leaves a lot of wasted space between each cell.
A conventional stacked-plate configuration is more space-efficient - squeezes the maximum amount of plate area into the space available.
Skibane is offline
post #8 of 32 (permalink) Old 04-14-2019, 10:41 AM
mtyler11's Avatar
Quoted: 439 Post(s)
^You can go considerably larger than Group 27F, particularly if you don't mind lengthening the battery cables.
I currently
I was hoping you'd chime in. I knew you run larger but couldn't remember what size you had.
[gone] 85 RX-7 5spd
[gone] 79 F-100 2wd
mtyler11 is offline
post #9 of 32 (permalink) Old 04-14-2019, 10:47 AM
whistler's Avatar
I have Odyssey’s in my Dodge. They were Optimas. Same with the Frontier. Optimas lasted 3 years and a few months.
post #10 of 32 (permalink) Old 04-14-2019, 11:06 AM Thread Starter
Quoted: 3 Post(s)
Thanks for the plugs for Odyssey, which are not available close to home.
I was asking about Interstate because they are widely available, though I don’t know if the new AGM battery is here yet.
Similar Threads
Raine's 2014 4x4 "KEIRA" Build Thread raine 2nd Gen Frontier Builds 840 04-16-2019 11:09 PM
Squeezing a Group 31 battery into your Frontier Skibane General Discussion 18 01-03-2018 07:19 PM
Dual battery and fridge install write up IAm_Not_Lost Interior Mods 13 04-06-2017 10:02 AM
Battery Problems or....? Frank_1898 General Discussion 10 12-05-2016 04:11 PM
Replaced the starter, still nothing. Cyondios 1st Gen Hangout 11 07-31-2014 10:34 AM
