Fuel Octane When Towing - Nissan Frontier Forum
post #1 of 42 (permalink) Old 04-16-2019, 07:14 PM Thread Starter
NissanFrontierPro4x's Avatar
Quoted: 174 Post(s)
the owner's manual says to use 87 octane or higher but when towing up steep hills i hear the valves rattling and such so i was wondering if some of you guys use 89 octane or maybe 93 octane when towing?
i was at 3/4ths of a tank of gas today and i filled up with 89 octane and it did seem to quiet down the valves a bit. what do you guys do?
2017 Glacier White Nissan Frontier Pro4x CC V6 6speed Manual
NissanFrontierPro4x is offline
post #2 of 42 (permalink) Old 04-16-2019, 07:30 PM
Skibane's Avatar
Quoted: 386 Post(s)
For towing, I don't think it's a bad idea.
Towing makes the engine work harder - which raises cylinder temperatures - which increases the chances of preignition ("pinging").
Higher octane gas is less prone to preignition.
2012 Super Black Crew Cab SV 2WD, Shrockworks bumpers, sliders & skids; Retrax Pro bed cover, Hypertech Max Energy Power Programmer, Yaesu FT-7900R 2m/70cm ham radio, Joying Dual-DIN Android head unit, Katana LED headlamp bulbs, Morimoto & RUN-D LED driving lights, Diode Dynamics LED exterior bulbs
Skibane is online now
The Following User Says Thank You to Skibane For This Useful Post:
whistler (04-17-2019)
post #3 of 42 (permalink) Old 04-16-2019, 07:44 PM
whistler's Avatar
Quoted: 1114 Post(s)
DescriptionKnocking in spark-ignition internal combustion engines occurs when combustion of some of the air/fuel mixture in the cylinder does not result from propagation of the flame front ignited by the spark plug, but one or more pockets of air/fuel mixture explode outside the envelope of the normal combustion front. Wikipedia
Not your valves. If your motor is pinging, it is telling you it needs higher octane or you got bad fuel.
I use the highest octane available but it is because I am hard on the truck.
whistler is online now
post #4 of 42 (permalink) Old 04-16-2019, 07:47 PM
vjmvjm's Avatar
Quoted: 125 Post(s)
And / or your knock sensors aren't working properly and / or your cooling system isn't up to the task.
Vic
vjmvjm is offline
The Following User Says Thank You to vjmvjm For This Useful Post:
whistler (04-16-2019)
post #5 of 42 (permalink) Old 04-16-2019, 09:05 PM
whistler's Avatar
Yes, just replaced 02 sensor and valve timing
solenoid .little over 7000 miles.
post #6 of 42 (permalink) Old 04-16-2019, 11:24 PM Thread Starter
Quoted: 174 Post(s)
it's not a constant thing. it only happens when going up a steep, long hill.
post #7 of 42 (permalink) Old 04-17-2019, 12:13 AM
whistler's Avatar
That is where the load increases and prone to do it then.
post #8 of 42 (permalink) Old 04-17-2019, 02:30 AM
Quoted: 69 Post(s)
try a different brand of fuel - it should not ping w/regular
'09 Suzuki Equator RMZ-4 w/Sport Package -Auto
ARE topper
LT245-75/16C Toyo Open Country A/T - summer
LT245-75/16E Firestone Winterforce - winter
09eq is offline
post #9 of 42 (permalink) Old 04-17-2019, 06:59 AM
Clint's Avatar
Quoted: 685 Post(s)
Only use top tier brand fuel, none the the off brand ones. Then see what happens.
The government cannot give to anybody anything that the government does not take from somebody else.
1991 Mazda Miata Limited Edition British Racing Green 5-speed
2012 Dodge Challenger SRT8 Yellow Jacket Edition 6-speed Stinger Yellow
2018 Nissan Titan SV Crew Cab 4X4 Deep Blue Pearl
2018 Nissan Rogue SV AWD Pearl White
Clint is offline
post #10 of 42 (permalink) Old 04-17-2019, 07:45 AM
Brummbar@65's Avatar
Quoted: 3 Post(s)
Guys, I am going to chime in here.
I have a 2019 Frontier and is got less than 1500 miles on it - so its new.
I filled up the first time with mid-grade fuel (89) after the full tank from the dealer when new; and, i notice the motor was considerably more quiet. I just chalked it up to the dealer gas being bad at the time and never thought much of it at the time. But, upon a few more fill-ups, I can say that mid-grade gas seems to be more agree-able for my truck. But, I also have to say that other than noise, I do not see any other impact - just normal driving - no towing. And, it does not seem to effect my MPG either.
Well, for what its worth,
Brummbar
2019 Frontier Pro-4X, KC
The Following User Says Thank You to [email protected] For This Useful Post:
Similar Threads
2001 3.3L SC: Won't start after knock sensor replacement m.funk 1st Gen Hangout 6 06-16-2017 12:46 PM
Fuel Spitting back through the filler neck Haystack1234 1st Gen Hangout 19 01-14-2017 01:48 PM
Frontier won't start after changing fuel sending unit, any tips or input? nmum General Discussion 5 10-04-2016 11:28 AM
fuel octane in my new 2012 frontier crew cab newenglander General Discussion 66 08-17-2015 11:39 PM
Fuel octane Squall_Line General Discussion 5 02-14-2015 11:12 PM
You may post new threads
You may post replies
