2001 Frontier - Belt Issues - Nissan Frontier Forum
 1Likes
post #1 of 10 (permalink) Old 04-11-2019, 12:13 PM Thread Starter
Quoted: 2 Post(s)
Exclamation 2001 Frontier - Belt Issues
I recently bought a 2001 Frontier with 208k miles on it. I put some work into it and have had no issues since. However, as of recently, my truck has been squealing for around 10-15 seconds each start. I know it's a belt issue but don't know much else about it. Instead of diagnosing which one is squealing, I might as well just change them all. If you have changed the belts in your Frontier, advice would be appreciated! How many belts are in the frontier? (Looks like 3 to me: Power Steering belt, AC and fan, and Serpantine ??) What exact parts and belts would I need to buy? Any more advice would be greatly appreciated
lsund003 is offline
post #2 of 10 (permalink) Old 04-12-2019, 06:48 PM
Clint's Avatar
Quoted: 684 Post(s)
Many times the tensioner and the idler pulleys are the culprit.
The government cannot give to anybody anything that the government does not take from somebody else.
1991 Mazda Miata Limited Edition British Racing Green 5-speed
2012 Dodge Challenger SRT8 Yellow Jacket Edition 6-speed Stinger Yellow
2018 Nissan Titan SV Crew Cab 4X4 Deep Blue Pearl
2018 Nissan Rogue SV AWD Pearl White
Clint is offline
post #3 of 10 (permalink) Old 04-13-2019, 12:30 AM
jackrussell's Avatar
Quoted: 14 Post(s)
belt squeal
check the tension pulleys the bearings in them can wear out and also look at the crank pulley when the harmonic balancer starts to separate it will cause the belts to squeal. (ask me how I know).
jackrussell is offline
post #4 of 10 (permalink) Old 04-13-2019, 01:32 AM
smj999smj's Avatar
Quoted: 426 Post(s)
If you want exact parts, you'll need to tell us whether it's a VG33E or a KA24DE engine. Personally, I get Bando brand belts from Rockauto.com. I'll go with Gates when it comes to idler pulleys, which Rockauto carries, as well.
smj999smj is offline
post #5 of 10 (permalink) Old 04-13-2019, 09:07 AM
Quoted: 6 Post(s)
Had to do my idler pulley on my 2.4 to get rid of my cold start-up squeal.
2003 Ext cab 4WD 3.3 AT - 2001 Reg cab 2WD 2.4 AT
arjadian is offline
post #6 of 10 (permalink) Old 04-13-2019, 11:39 AM
Cusser's Avatar
Quoted: 385 Post(s)
My two 2.4L Frontiers have had belt squealing in the past. I use Gates or Gatorback belts. My 1998 has had both PS and AC idlers replaced (Gates) and the 2004 the PS idler (Gates).
Belts - this is what I use:
Alternator/water pump Nissan 02117-90513 Gates/CarQuest 7355 9.5mm x 920mm
Power steering Nissan 02117-25023 Gates/CarQuest 9495 Goodyear Gatorback 17494 12.5/13mm x 1260mm
AC Nissan 02117-92523 Gates/CarQuest 9365 12.5/13mm x 935mm
'98 2WD, 4-cylinder, 5-speed, white regular cab, purchased in 2004 with 100K on it for the kids to drive, now it's back with us, 237K. 2004 King Cab 2WD, 4-cylinder, 5-speed, electric blue purchased in Dec. 2011 at 89K. Also 1988 Mazda B2200 Cab Plus truck (since 1994, 217K), 2WD, 4-cylinder, 5-speed, great truck. And 1971 VW Convertible (mine since 1976) and 1970 VW (260+K, mine since 1972).
Cusser is offline
post #7 of 10 (permalink) Old 04-15-2019, 10:05 AM Thread Starter
Quoted: 2 Post(s)
I drive a 3.3L V6, so it is a VG33E engine. From what I've read I see this engine has a timing belt and in the manual it simply says "Generator Belt". That could mean a variety of things ~ AC belt, power steering belt, & alternator belt
Thanks
lsund003 is offline
post #8 of 10 (permalink) Old 04-15-2019, 06:51 PM
Bamps's Avatar
Quoted: 146 Post(s)
There is an idler pully, in other words it does no function but to guide the belt. My 2000 desert runner had the same issue. I changed it out and that squeal went away. They, as someone else mentioned, are notorious for freezing up bearings inside and squealing . It will gradually get worse if unchecked
2013 Frontier CC Pro-4X
Auto trans
1aauto tow mirrors
Pioneer MVH 2400NEX head unit
aFe drop in air filter
Nisstec Radflo OE Length Ultimate lift kit
Nisstec UCA and 1 top plate
3 leaf AC AAL rear
Hankook ATM LT285/75 R16 (load range E)
Flowmaster 40 series muffler
Bamps is offline
post #9 of 10 (permalink) Old 04-16-2019, 08:01 AM
smj999smj's Avatar
Quoted: 426 Post(s)
There will be three belts. As I said, I use Bando (or genuine Nissan) when I can, as they do make some of the OEM belts for Nissan and are always the correct size:
Alternator: Bando # 5PK800
A/C: Bando # 4PK1345
P/S and water pump: Bando # 5PK1235
There are two idler pulleys, a smooth one for the P/S and a grooved pulley for the A/C:
P/S idler pulley: Gates # 38005
A/C idler pulley: Gates # 36314
These have nothing to do with the timing belt, but, when I do a timing belt, I get the following:
Gates # TCKWP249 Timing Belt Component Kit with water pump
Pentosin Pentafrost A2 (green) antifreeze
1-gallon distilled water (Walmart)
Nissan 21200-V720A thermostat (gasket is RTV sealant)
Nissan 13042-0B001 (two) camshaft seals
Nissan 13510-10Y10 (07/2000-07/2001) or 13510-10Y12 (07/2001 and later) front crank seal
Nissan 14055-4S110 coolant bypass hose
If you want to replace, or for missing timing cover grommets and/or the seals that sit on the ends of the water pump, get Aisin # SKN001, which also includes the two front cam seals and front crank seals.
Radiator hose set, as needed:
Gates # 22516, 22517 and 22478.
post #10 of 10 (permalink) Old 04-16-2019, 04:53 PM Thread Starter
Quoted: 2 Post(s)
Thank you very much! You were a huge help.
Will send an update after I install the new parts
lsund003 is offline
Similar Threads
Troubleshooting Issues with a 2004 Frontier SC LadyDragonshade DIY - Do It Yourself / Tech Tips 9 04-21-2018 09:14 AM
2001 Frontier 2WD transmission oil change silentz 1st Gen Hangout 6 04-06-2016 07:54 AM
'14/'15 Frontier Issues so far? Sgt_Lipton General Discussion 163 01-02-2016 10:12 AM
2001 Frontier 100 degree heat from heater when heater off and disconnected. amazingmaz General Discussion 3 06-14-2015 10:33 AM
2nd Trip To A New Frontier LAfireboyd New Member Introductions 7 06-09-2015 05:39 AM
