Wheel spacers...again. - Nissan Frontier Forum
 1Likes
post #1 of 4 (permalink) Old 04-11-2019, 04:21 PM Thread Starter
GKnapp's Avatar
Quoted: 7 Post(s)
- Disclaimer: I have run wheel spacers before without issue and believe they are inherently safe.
Spidertrax Wheel Spacers. Yes, I know, another thread about wheel spacers but bear with me. I have been reading multiple threads on multiple forums and I can't quite seem to answer my question.
The Frontier has a FWC pop-up on it full time. 800lbs dry, 900-1000lb loaded. I want a wider stance to provide a bit more stability on the highway. I also am fond of the stock wheels, I like the look and the suit the vehicle very well. My go to solution would be spacers but I am concerned about the added constant load. I have read plenty of threads about towing with spacers with various conclusion on whether or not to run them. But I feel there is a fundamental difference when towing that load on trailer and carrying it in the vehicle. I am worried about the added weight and stress being applied to the rear spacers; coming down off a rock ledge or 50 miles of rough washboard.
With this constant load am I adding 24 more points of failure? Am I over thinking this? Is there a existing thread addressing this? DID I FORGET HOW TO USE THE SEARCH FUNCTION??
As I said, I have run spacers before but never with this much weight over stock.
Thanks for all the help.
Hmmph
GKnapp is offline
post #2 of 4 (permalink) Old 04-11-2019, 05:31 PM
Blazepro4x's Avatar
Quoted: 43 Post(s)
Let's apply some simple physics. Equal and opposite reaction blah blah.. if you put more weight in or on the back of your truck whether it is a camper or a trailer. you are putting stress on the spacer. Your leaf springs compress because of the weight, your leaves are connected to the axle, your axle is connected to the spacer. doesn't matter where you put it. weight is weight. however, I would argue that the camper is even worse than a trailer Since it sits directly over the axle and is constantly pushing down. plus its always in the bed unlike a trailer you can remove easily. I would call or see if spidertrax has a weight limit they were designed for. Also if you do some offroading well.....
i don't have the money to measure how fast a tire of a frontier takes to fall say,... a foot with 1000lbs on the bed. But regardless, simple physics will tell you that if something falls, the force it produces exceeds the static weight of said object. in other words, the camper will "weigh" more if it's going offroad. so take that into consideration while checking the weight limit. also, make sure that the weight they give you isn't it's static maximum. If you can do it, do it! but make sure your math is correct or you won't like the outcome.
Nothin to see here.
Blazepro4x is offline
The Following User Says Thank You to Blazepro4x For This Useful Post:
GKnapp (04-12-2019)
post #3 of 4 (permalink) Old 04-11-2019, 05:42 PM Thread Starter
GKnapp's Avatar
Quoted: 7 Post(s)
Thank you. That is the type of critical thinking I am looking for.
Hmmph
GKnapp is offline
post #4 of 4 (permalink) Old 04-12-2019, 06:08 PM Thread Starter
GKnapp's Avatar
Quoted: 7 Post(s)
Just in case anyone wanted this info also, I spoke with Spidertrax today. The said the weight limit of the wheel spacer is targeted at the GVWR. Although they stand behind their product as something extremely strong, such as the studs being much stronger than the stock studs, they recommend staying under the GVWR.
Food for thought.
Hmmph
GKnapp is offline
  Nissan Frontier Forum > Mods and Technical Discussions > Wheels, Tires, and Brakes
Similar Threads
Frontier 1.5" Hub Centric Wheel Spacers rlholland OffRoad / 4x4 9 03-27-2019 12:33 PM
1.5" SpiderTrax Hub Centric Wheel Spacers Brian Amundson Parts 3 12-28-2018 01:15 PM
How to Install New wheel Studs w/ Wheel Stud Installer Tool jonaz15 DIY - Do It Yourself / Tech Tips 1 11-03-2017 10:16 PM
Rubbing with wheel spacers? DonBrizzel OffRoad / 4x4 17 07-28-2015 03:23 PM
Wheel Spacers FloridaPro4x General Discussion 3 11-05-2014 10:25 AM
You may post new threads
You may post replies
