Vk56 6-speed - Nissan Frontier Forum
post #1 of 15 (permalink) Old 04-12-2019, 01:58 PM Thread Starter
Vk56 6-speed
I'm inquiring to see if anyone has completed or is in the process of completing this swap. You can see my VK56 and 6-Speed swap here:
https://www.thenewx.org/forum/30-xte...ct-thread.html
I'm having issues and want to have someone to compare to. I've searched threads all over and seems everyone talks about the swap but never posts results or videos. All ther threads are dead ends. Driven Desire is the only ones who have provided feedback and it's their kit.
The problem I'm having is it won't go into gear with the driveshaft attached but will go into gear without it when the engine is running. I contacted one of the first 6-speed swaps but he sold his truck for a Titan. Any info would help. I've already taken the transmission out once and bled both master and slave multiple times.
kebler2005 is offline
post #2 of 15 (permalink) Old 04-12-2019, 03:53 PM
Nissan4Life's Avatar
Quoted: 989 Post(s)
sounds like the clutch is not releasing. The master and slaves can be functioning properly. Maybe the slave doesn't have enough throw? The clutch is wrong? The fork is wrong? Fork is bent? Is there a way to confirm this. Like a cheap bore scope into the fork hole to see if the input shaft to the tranny is spinning when the clutch pedal is depressed. Or scope into the fill plug to see if the input shaft is spinning?
06 KC NISMO 4x4 6sp
Nissan4Life is offline
AndysLog (04-14-2019)
post #3 of 15 (permalink) Old 04-12-2019, 10:10 PM Thread Starter
It's spinning because it nudges when I attempt to shift gears. I wish I had someone to compare setups too.
I guess Harbor freight here I come haha.
The first black line is how far the fork goes when the slave rod is pushed out. The second black line is how far I was able to push with a pry bar without the slave.
ID:	291677   Click image for larger version
post #4 of 15 (permalink) Old 04-13-2019, 03:24 PM Thread Starter
She's alive guys... Still got some buttoning up to do and few upgrades. Thanks to Brennan from Driven Desire for all the help.
https://youtu.be/E8zRrVIQZHU
https://youtu.be/rn25NgM7vBc
The Following 2 Users Say Thank You to kebler2005 For This Useful Post:
AndysLog (04-14-2019), Sixspeed-SV (04-14-2019)
post #5 of 15 (permalink) Old 04-13-2019, 10:33 PM
Quoted: 47 Post(s)
What was the issue? Clutch alignment?
2011 FRONTIER SV 4X4 6SPD CC/LB Knight Armour
Lifted, truetrac, injen, ims, bullydog, skids, HID projectors, WRP underdrive crank pulley, blah, blah blah
speed demon is offline
post #6 of 15 (permalink) Old 04-14-2019, 12:40 AM Thread Starter
Not sure really. I figured I should start it and let it warm up for the first time outside. I planned on starting it in gear and see what it would do. I let it idle down and it went into gear after pumping the clutch a bunch of times. Then after that it drove like normal. I have no clue. Maybe the upgraded pressure plate needed to be broken in differently.
post #7 of 15 (permalink) Old 04-14-2019, 11:43 AM Thread Starter
Plus if the clutch wasn't aligned the transmission wouldn't go in. It went in.
post #8 of 15 (permalink) Old 04-14-2019, 02:22 PM
AndysLog's Avatar
Quoted: 1158 Post(s)
Feedback Score: 9 reviews
could be fluid related. see a lot of hard gates when cold.
glad its up and running!
AndysLog is offline
post #9 of 15 (permalink) Old 04-15-2019, 09:07 AM Thread Starter
While it was exciting for the time being, I have to take the trans back out. There is oil leaking out of the bell housing. I already changed the rear main and resealed the rear crank cap. It won't shift into reverse when running or start in reverse.
post #10 of 15 (permalink) Old 04-15-2019, 10:20 AM
AndysLog's Avatar
sounds like a hodge podge.
did you get to see and hear everything working and operating before purchase?
AndysLog is offline
Similar Threads
VK56 6 Speed Xterra brother kebler2005 New Member Introductions 2 04-12-2019 11:54 PM
6 speed questions! Nardi New Member Introductions 4 10-28-2018 08:11 PM
Feeler: 2nd Gen VK56 Conversion Harness SinisterFrontier06 General Discussion 45 03-22-2018 12:35 AM
Tire and Rear Ratio Speed Calculator bobus8 Wheels, Tires, and Brakes 7 05-28-2015 12:21 PM
HTML code is On
