Aftermarket temperature gauge - Nissan Frontier Forum
 5Likes
post #1 of 11 (permalink) Old 04-07-2019, 02:31 AM Thread Starter
butterman2473's Avatar
Quoted: 144 Post(s)
After my truck overheated a couple of weeks ago I decided that I want a real temperature gauge.
Now that I have the gauge in hand, I can't decide on the best way to install the sensor and am seeking some input/advice of any kind.
I have two options from what I can see.
I was thinking about replacing the plastic connector that's between lower hose and thermostat housing hose with the aluminum adapter with sensor. (1st Pic)
Also thought about getting a 1/8" npt female to m10 male adapter and installing the sensor in place of the oem temp gauge sensor. Thus disabling the oem temp gauge. (2nd pic)
Any and all thoughts or suggestions on the best way to install this sensor are welcomed and very much appreciated.
2004 Nissan Frontier XE KC KA24DE
butterman2473 is offline
post #2 of 11 (permalink) Old 04-07-2019, 03:55 AM
whistler's Avatar
Quoted: 1089 Post(s)
I use an adapter. I found it on Ebay . I could not buy the material for what I paid for it. It works fine.
butterman2473 likes this.
whistler is offline
butterman2473 (04-07-2019)
post #3 of 11 (permalink) Old 04-07-2019, 08:54 AM
RyanD1966's Avatar
Quoted: 255 Post(s)
Easiest route ever. Mounts in the upper rad hose, five minutes cut the hose and install the adapter. The sender that came with the Autometer kit fit perfectly, a little teflon tape wrap and you are golden. Threaded in perfectly. Dont forget a ground lead back to the fender etc or you will have no signal. Mine has been in for almost a year now and works great. Replace the junk Chinese supplied hose clamps with some Ideals and the install's done.
ID:	291321   Click image for larger version
ID:	291323   Click image for larger version
Why make it only good enough when you can double the budget and build it like NASA?
Exterior: 5 LED light bars, 2 x 16" bumper mount, 1 x 42" roof mount and 2 x 22" side-mounts, APG iArmour side steps, LED cargo and reversing lamps. M226 axle vent mod, Firestone RideRite airbags
Engine Bay: K&N filter, 7 circuit fuse & relay bank, ECT sensor alum adapt housing, 630CFM trans cooler fan - thermo & override swtch
Cabin: Dynamat equiv in doors, all interior LED illum, engine coolant and trans temp gauges by AutoMeter, overhead console 6 switch control bank
Audio: Morel Maximo 6.5"s, Sundown Audio 2.75" midtweets
Cargo Bed: Ridgid toolbox, GlassFibre shovel, adze and sledgehammer > UtiliTrak
OverlandBound Member# 16310
RyanD1966 is offline
The Following User Says Thank You to RyanD1966 For This Useful Post:
post #4 of 11 (permalink) Old 04-07-2019, 09:28 AM
Cusser's Avatar
Quoted: 385 Post(s)
I'm leaning toward this (#1), if you feel the need to add an aftermarket temperature gauge.
That way you'd retain the stock functionality, which most likely is not detected by the ECU (that one would be a different sensor)...but just in case.....
'98 2WD, 4-cylinder, 5-speed, white regular cab, purchased in 2004 with 100K on it for the kids to drive, now it's back with us, 237K. 2004 King Cab 2WD, 4-cylinder, 5-speed, electric blue purchased in Dec. 2011 at 89K. Also 1988 Mazda B2200 Cab Plus truck (since 1994, 217K), 2WD, 4-cylinder, 5-speed, great truck. And 1971 VW Convertible (mine since 1976) and 1970 VW (260+K, mine since 1972).
Cusser is offline
The Following User Says Thank You to Cusser For This Useful Post:
post #5 of 11 (permalink) Old 04-07-2019, 10:21 PM Thread Starter
Quoted: 144 Post(s)
Ebay is where I got mine from too. Which hose do you think would provide a more accurate reading, upper or lower?
https://www.amazon.com/gp/product/B0...tierconvert-20
The gauge I have is a 2 wire.
Any particular reason you chose the upper hose and not the lower? Which do you believe would provide a more accurate reading? Why is your water temp gauge crooked? Haha...just giving you a hard time.
I believe the sensor doesn't communicate with the ecu/ecm. The bigger one next to it does. But I would hate to lose oem gauge functionality so I am leaning toward using the aluminum adapter.
post #6 of 11 (permalink) Old 04-07-2019, 10:32 PM Thread Starter
Quoted: 144 Post(s)
I don't know if the answers to my questions would be any different due to the fact that my truck is a 1st gen KA24DE engine while you guys are 2nd gen....with Cusser being the exception.
post #7 of 11 (permalink) Old 04-07-2019, 10:40 PM
RyanD1966's Avatar
Quoted: 255 Post(s)
Ebay is where I got mine from too. Which hose do you think would provide a more accurate reading, upper or lower?The gauge I have is a 2 wire.
Any particular reason you chose the upper hose and not the lower? Which do you believe would provide a more accurate reading? Why is your water temp gauge crooked? Haha...just giving you a hard time.I believe the sensor doesn't communicate with the ecu/ecm. The bigger one next to it does. But I would hate to lose oem gauge functionality so I am leaning toward using the aluminum adapter.
Butterman, the crooked guage is a race car trick, they spin their gauges so that all the pointers line up at the 12 oclock position when the readings are normal. If you see something out of the corner of your eye not standing up, then you know you have an issue. I haven't got around to clocking the trans temp gauge yet cause I had no idea what the normal range would be for that indicator when I built the pod. As to the hose chosen, the upper was easiest to reach in a very tight engine bay, so upper it was. Would the lower hose temp be different? Quite possibly, but this at least gives me a real actual reading, w/ useful information, not that moronic three position "tree" that's either Cold, Normal or YJBYE ( You Just Blew Your Engine ). GM used to be famous for that gauge style as well, I dont think they do that anymore.
post #8 of 11 (permalink) Old 04-07-2019, 10:42 PM
Cusser's Avatar
Quoted: 385 Post(s)
The Cuss is always an exception.
I'd say use upper hose because that would be coming from the thermostat outlet.
Cusser is offline
post #9 of 11 (permalink) Old 04-07-2019, 11:30 PM Thread Starter
Quoted: 144 Post(s)
But what if I have a thermostat stuck closed situation? Would I then not get a true temperature reading?
post #10 of 11 (permalink) Old 04-07-2019, 11:43 PM Thread Starter
Quoted: 144 Post(s)
That's exactly why I'm doing this.
Lol. I don't doubt that at all sir.
Last edited by butterman2473; 04-07-2019 at 11:47 PM. Reason: Automerged Doublepost
Similar Threads
Oil temperature gauge install iclick General Discussion 0 02-04-2019 03:10 PM
Delay in selected vent temperature taking effect mancat General Discussion 5 10-10-2017 11:47 PM
Temperature Gauge Problem AdamR46 4 Banger Lounge 7 03-12-2017 04:45 PM
Oil Temperature gauge chris General Discussion 4 03-10-2015 02:55 AM
aftermarket gauge install REYoung 1st Gen Hangout 1 01-14-2015 05:51 PM
