Need to upgrade suspension on '13 Frontier P4X - Nissan Frontier Forum
post #1 of 12 (permalink) Old 04-05-2019, 04:01 PM Thread Starter
Quoted: 24 Post(s)
Please help me figure out my suspension upgrade(s)….
Current: My truck has 2” front spacers and adjustable rear shackles at 1.5”, as well as 2” DIY BL. The rear springs are flat (actually, a bit worse than that).
Want: Upgrade front and rear suspension.
- Rear: We’ve purchased a small travel trailer (<400# tongue weight and ~3800# GVWR). I need to beef up the rear and would like to get it lifted back where it was before the stock springs flattened.
- Front: The ride is a bit harsh and I get coil bucket contact. I’d like to improve the suspension rather than just lift it.
Situation: I had ‘purchased’ Nisstec’s MK84 kit with UCAs and Alcan rear springs. That didn’t go through (I’d be glad to discuss privately if anyone wants the scoop). I’ve got the Alcan rear springs (400# over stock) on the way directly from Alcan.
I *have to* sort out the rear, as I can’t tow the trailer as it sits now. So that’s top priority. I guess I just need shocks to go with the new springs?
And for the front, I’d still like to duplicate the current lift, but improve ride quality and suspension travel. What do y’all suggest?
TIA,
Jon
illzoni (aka Jon)
2013 Frontier Pro4X
www.illzoni.com
illzoni is offline
post #2 of 12 (permalink) Old 04-05-2019, 06:20 PM
whistler's Avatar
Quoted: 1078 Post(s)
For the rear, I would have gone with airbags rather than 400lb. Springs. You can adjust to your load. I am guessing but I think your truck will be really harsh riding when not towing.
If you want to improve how your suspension works, your best option is a Titan swap. Just my opinion.
whistler is online now
Sabretooth (04-06-2019)
post #3 of 12 (permalink) Old 04-05-2019, 07:22 PM
Blazepro4x's Avatar
Quoted: 40 Post(s)
I agree with whistler, I would try to cancel your order and get bags. Did you talk to alcan? i doubt they would of recommended HD springs on a stock weight truck. HD leafs are for trucks who CONSTANTLY have weight in the back. When you're not towing a trailer the ride is going to be awful.
You're not going to get much better in the front unless you get aftermarket ucas like in the kit you where talking about. or you will have to go with a full titan swap which is titan lca, uca ,tie rod ect. The best kit imo you can get without going titan swap is the mk84 or similar.
Nothin to see here.
Blazepro4x is offline
The Following User Says Thank You to Blazepro4x For This Useful Post:
whistler (04-05-2019)
post #4 of 12 (permalink) Old 04-05-2019, 07:30 PM Thread Starter
Quoted: 24 Post(s)
I do carry tools. And have a ladder rack with two ladders. Total is probably ~300#
Also, Alcan was saying I could go up to 500-600# over stock and it would be fine. Seems stock is really weak.
illzoni (aka Jon)
2013 Frontier Pro4X
www.illzoni.com
illzoni is offline
post #5 of 12 (permalink) Old 04-05-2019, 11:50 PM
Quoted: 1602 Post(s)
I'm 100% street. W/ ARE bedshell added in, I frequently haul 600-650 lbs in the bed. Installed HD leaf springs from generalspringskc.com, they're rated for 400lbs and I'll say they improved my overall ride quality when it comes to handling and speed bumps/etc...whether loaded or unloaded. These provided 1.5" of rear lift. I've since upgraded to Bilstein 5100s and set the adjustable fronts to 1.5" of lift. My ride quality is even more improved as a result. Win-win!! Ride is NOT jittery at all.
https://www.generalspringkc.com/product_p/69-285hd.htm
Bit of background:
I was told that airbags (installed at 12k miles on odo) would extend the life of my factory leaf springs, and this just was not the case for my work truck scenario. Rear leaves were 'W' shaped by 30k miles. I chose to retain the airbags w/ the HD leaf packs as they are a great add-on for leveling purposes.
My greatest fear was regretting these mods...and they both (HD leaf springs + Bilstein 5100s) made a quality difference in how my truck performs while providing a competent and planted ride at all speeds.
'15 SV KC, 4.0, 6-sp, 4x2 DD/WT
_________
185K miles w/ original factory distributor, U-joints, cats & clutch
shift_RUSH is offline
post #6 of 12 (permalink) Old 04-08-2019, 02:25 PM Thread Starter
Quoted: 24 Post(s)
TIA,
Jon
The Alcan springs are on the way. What shocks would you suggest to go with them?
And I have a set of stock shackles (had do get some, as I boogered up the old ones getting them off). Anything else needed for the rear?
I've heard many good things about the MK84s, but they're not an option. What can I do in front that's comparable?
Thx,
Jon
illzoni (aka Jon)
2013 Frontier Pro4X
www.illzoni.com
illzoni is offline
post #7 of 12 (permalink) Old 04-15-2019, 12:14 AM Thread Starter
Quoted: 24 Post(s)
What about Bilstein 6112/5125 shocks?
illzoni (aka Jon)
2013 Frontier Pro4X
www.illzoni.com
illzoni is offline
post #8 of 12 (permalink) Old 04-15-2019, 02:44 AM
whistler's Avatar
They wom’t Improve travel. I know that and questionable about ride quality.
Hope it works out for you.
post #9 of 12 (permalink) Old 04-15-2019, 03:06 AM
whistler's Avatar
Bit of background:
Remember that the 600-650 lbs are spread over a greater area which distributes the weight evenly. Take that same weight and put it at the very rear if the bed. Big difference. That is where the airbags come into play like you mention. Leveling.
post #10 of 12 (permalink) Old 04-15-2019, 09:17 AM
Quoted: 7 Post(s)
I would get a weight distributing hitch if you dont already have one. That will level the truck and add weight back on the front tires.
2018svcc4x4 is offline
Similar Threads
*UPDATED* Suspension Lifts and Body Lifts for 2005+ *PLEASE READ BEFORE POSTING HERE* JeniorNV Suspension 10 03-22-2018 09:35 AM
2005-2015 Nissan Frontier 12 Piece Set Steering & Suspension Kit with (2) Front Upper 1AAuto.com 1A Auto Parts 1 07-10-2017 03:08 PM
05 Frontier Rear suspension Desert_Ridder Parts 14 02-21-2017 06:34 PM
2005-2015 Nissan Frontier Black Textured Manual Towing Dual Arm Mirror Pair Upgrade 1AAuto.com 1A Auto Parts 2 11-09-2015 03:56 PM
02 Frontier Crew Cab w/ 3" suspension lift/ want to level out the front Jgehret76 1st Gen Hangout 7 01-21-2015 07:15 PM
