Bilsteins W/ Spacer - Nissan Frontier Forum
post #1 of 12 (permalink) Old 01-08-2018, 11:03 AM Thread Starter
Enon535's Avatar
Quoted: 38 Post(s)
Bilsteins W/ Spacer
I have a 2015 SV Frontier 4X4 currently with SPC UCA's and a rough country 2.5" top mount spacer lift/level with 1.5" shackles in the rear. I recently purchased the adjustable Bilstein 5100's for the front.
So with being said i am looking to get at least 3 inches of lift in the front and then level out the rear. Is it better to keep the spacer and set the Bilsteins on the .5" setting or get a smaller spacer and step up the Bilstein's to say 1.5" or 2"?
Any other options to combine with the 5100's is also welcome. Thanks
2015 SV CC 4x4 V6 W/VTP - Super Black KH3 - Tinted Windows - Black Rain Guards - BAK Industries Revolver X2 Tonneau Cover - Weather Tech Floor Mats - 2.5" Front spacer & 1.5" Rear Shackle - SPC Upper Control Arms - 16x9 ATX Cornice 195 Wheels - BFGOODRICH KO2's 285/75/16 - Mesh Grille Mod - Katana LED's - Axle Vent Mod
Enon535 is offline
post #2 of 12 (permalink) Old 01-08-2018, 12:54 PM
Nissan4Life's Avatar
Quoted: 990 Post(s)
1.5" spacer and bils set to 1.5.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
post #3 of 12 (permalink) Old 01-08-2018, 01:08 PM Thread Starter
Enon535's Avatar
Quoted: 38 Post(s)
I am also a little confused on the bump stops, do i need them or not? and can you explain why i would or would not need them
Enon535 is offline
post #4 of 12 (permalink) Old 01-08-2018, 01:24 PM
raine's Avatar
Quoted: 1528 Post(s)
Bump stops on the OEM UCA keep it from banging on the coil bucket at full extension -CBC, a.k.a. "Coil Bucket Contact", see the 4th question in the Suspension Sticky here (read the whole thing, you'll learn a lot):
https://www.clubfrontier.org/forums/f...ng-here-63966/
Since you're looking to go over a 2" lift, CBC is definitely possible. So either you use the bump stops to help absorb impact when the UCA does contact the coil bucket, or you don't use them and hear a nice clang noise when they make contact.
Note that if you want to go above 2" lift you should consider aftermarket UCAs which don't have CBC and allow you to get the front end alignment dialed in.
- Raine.
This is my truck.
This is my weekend ride.
Read: The End-All Guide to Camber Bolts and UCAs for 2nd-Gen Lifted Frontiers
TYPE 2014 CC SV 4x4 VTP COLOR NIGHT ARMOR LIFT 3.5"/2.5" NAME KEIRA
SUSP: Custom King Shocks . Total Chaos . Level-8 . Deaver . Nisstec . Bilstein . PRG . BF Goodrich
EXT: Rigid Industries . P&P . PIAA . White Knuckle . White Rhino . Truxedo . Firestik . BlueSea
A/V: DNX-892 . TWK-88 . PDX-V9 . HSK-165 . DCX-165.3 . 2x 10TW1-4 . 2x Cameras . Super NES
MODS: Reservoir Mounts . Power Tailgate Lock . Custom CB Antenna Mount . Trailer Plug Relocate
MORE: Midland . UltraGauge . Raingler . Working OEM SWC, Bluetooth, USB . Some Cool Stickers
raine is offline
post #5 of 12 (permalink) Old 01-08-2018, 01:34 PM Thread Starter
Enon535's Avatar
Quoted: 38 Post(s)
I have SPC UCA's I was just curious if i still needed the bump stops as i have done some research and got conflicting answers.
Enon535 is offline
post #6 of 12 (permalink) Old 01-08-2018, 01:51 PM
raine's Avatar
Are your SPC's hitting the coil bucket? if not, then you don't need them.
- Raine.
This is my truck.
raine is offline
The Following User Says Thank You to raine For This Useful Post:
Enon535 (01-09-2018)
post #7 of 12 (permalink) Old 01-08-2018, 02:48 PM Thread Starter
Enon535's Avatar
Quoted: 38 Post(s)
Is there anything else i need to buy to protect the shocks/cv's? After re reading the lift sticky i got in to the travel numbers post from PRG and it kind of confused me about the 5100's/SPC UCA/spacer lift and the truck self destructing via droop and compression. Sorry for all of the questions but i am kind of new to the inner workings of offroad trucks. I just want something of decent quality that i can have a little fun with and not have to fork out more money for uneducated choices/decisions
Enon535 is offline
post #8 of 12 (permalink) Old 01-08-2018, 02:54 PM
Quoted: 990 Post(s)
Not upper control arm bump stops. Bottom out bumps located on the the LCA. You will probably need them. The 5100 are even longer than the 4600. They will crush on full compression with the stock bumps.
This is jsut from what I have read on the prg site. I can only confrim that the 5100 are long.
Would be better to go for the 1" spacer and the set the 5100 on 1.5". But then you won't get your 3". Better this way.
06 KC NISMO 4x4 6sp
post #9 of 12 (permalink) Old 01-08-2018, 03:05 PM
raine's Avatar
Well I was talking about CBC, then OP mentioned he had SPC UCAs, so I figured OP was asking about UCA bump stops
- Raine.
This is my truck.
raine is offline
post #10 of 12 (permalink) Old 01-08-2018, 04:53 PM Thread Starter
Enon535's Avatar
Quoted: 38 Post(s)
How much taller would the aftermarket LCA bumps need to be if i went 1.5spacerx1.5bilstein?
Enon535 is offline
