Bilstein 5100 max height with 3" spacer - Page 3 - Nissan Frontier Forum
 1Likes
post #21 of 26 (permalink) Old 04-12-2019, 01:59 PM
Nissan4Life's Avatar
Quoted: 990 Post(s)
The 4 banger frontier is different than all the other frontiers. This is what I would do.
-Remove existing coil over and spacer.
-take new 5100 add spacer, NO SPRING. Remove boot so that you can see the shaft and body. Make sure to install boot spacer/washer, use old one. Fully compress, mark this location on shaft. Install on truck.
-cycle suspension using floor jack. At full compression see if the shock reaches max compression first, or if the lower control arm hits and compresses the bump stop first. At max extension or drop, see if the UCA touches the coil bucket. coil bucket contact is ok. Shock crush is not. If you get shock crush either add a taller LCA bump stop, or a smaller lift spacer.
-remove 5100. Install spring to whatever height setting you want. Go for full 2". Install boot with spacer/washer, or no boot, but that spacer/washer must be there.
-Install whole get up. See where the UCA sits relative to the CB. Take for text drive. If all good. Drink beer be happy. If too tall/stiff or UCA too close to CB, drop it down a notch.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
post #22 of 26 (permalink) Old 04-12-2019, 06:24 PM
Quoted: 990 Post(s)
Originally Posted by that_four_bangin_frontier View Post
it doesn't work. sadly I took it to a shop and they tried at 1" with the 3" spacer it had coil bucket contact but I did contact greg at prg and he said if I run the v6 frontier's springs I can get an extra inch. maybe that'll work and help y'all out. aint many running the 4cyl with a suspension or body lift that I know of on here
There is nothing wrong with coil bucket contact (CBC).
06 KC NISMO 4x4 6sp
post #23 of 26 (permalink) Old 04-12-2019, 11:23 PM
whistler's Avatar
Quoted: 1085 Post(s)
Maybe not but travel must be severely limited.
I have seen coil buckets cracked from it.
Even if it didnít , it would drive me nuts!.
whistler is online now
post #24 of 26 (permalink) Old 04-15-2019, 10:30 PM
Michael Dickenson's Avatar
Quoted: 5 Post(s)
So if one had 1.5" spacers up front, 5100's set to the stock height would be fine right? This is with aftermarket UCA's.
I believe based on what I see, the only other thing required would be bumps stops on the LCA's right?
Sent from my SM-N960U using Tapatalk
Michael Dickenson is online now
post #25 of 26 (permalink) Old 04-15-2019, 11:25 PM
whistler's Avatar
I think you want them on the coil bucket. Or upper arm. Trying to lessen the coulbuvket clang?
post #26 of 26 (permalink) Old 04-16-2019, 08:05 AM
Quoted: 5 Post(s)
That shouldn't be a problem with aftermarket UCA's.
Similar Threads
2009 lift with 5100 bilstein shocks, 2" spacer in front and 2"5 blocks in back Anthony123 New Member Introductions 1 04-26-2018 06:36 PM
*UPDATED* Suspension Lifts and Body Lifts for 2005+ *PLEASE READ BEFORE POSTING HERE* JeniorNV Suspension 10 03-22-2018 09:35 AM
Heeeellllppp!! Bilstein 5100 Max Lift Compresses Spring Too Much??? Huskaroo Suspension 16 11-29-2017 08:45 PM
F/T: Bilstein 5100 front&rear+PRG 1/2" spacer, 5125 rear. JSutter Parts 8 08-26-2016 09:28 PM
Potentially New Bilstein Coilover! 6112, a budget minded beefy 5100 glamisdude Suspension 58 02-01-2016 04:11 PM
