Bilstein 5100 max height with 3" spacer - Nissan Frontier Forum
 1Likes
post #1 of 26 (permalink) Old 03-19-2019, 04:05 AM Thread Starter
that_four_bangin_frontier's Avatar
Quoted: 7 Post(s)
so I already have a supreme suspensions (eBay) 3" front and 2" rear leveling kit and I just ordered Bilstein 5100 for the front. I've already trimmed the coil bucket. im looking for some advice. if I run the Bilstein at max height with the spacer how much lift would I need in the rear? im not so worried about the ride quality as I drive it on highway mostly. has anyone tried this?
that_four_bangin_frontier is offline
post #2 of 26 (permalink) Old 03-19-2019, 11:41 AM
Nissan4Life's Avatar
Quoted: 990 Post(s)
You can not run a 3" lift spacer with a 5100 set at max (2") and expect 5" of lift. There isn't 5" of suspension travel to be able to gain you 5" of lift. With your current set up, you have as much lift as you can pump out of your suspension. If you want more you will need to get a drop bracket lift or a body lift.
And it is not really about ride quality. Years ago in High School we lifted a Nissan Hardbody truck to the MAX. Arms all the way down so there was no more down travel. 2wd, and then put 31" tires on it. 99% highway driven. One day going down US101, there is a section through Santa Barbra with some "whoops" (just unsmooth sections at the over pass). Bounced his suspension tore the mounts to 2 of his control arms off. His awesome lift couldn't even handle going down the highway.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
The Following 2 Users Say Thank You to Nissan4Life For This Useful Post:
erturne (04-11-2019), whistler (04-11-2019)
post #3 of 26 (permalink) Old 04-11-2019, 01:44 AM Thread Starter
Quoted: 7 Post(s)
I just figured out that my actual spacer is 1.5 and not a full 3" would it still be overkill?
post #4 of 26 (permalink) Old 04-11-2019, 02:18 AM
Tommy Pearson III's Avatar
Quoted: 185 Post(s)
3 inches is max with stock arms
Tommy Pearson III is online now
post #5 of 26 (permalink) Old 04-11-2019, 02:19 AM Thread Starter
Quoted: 7 Post(s)
if set the bilsteins at 1.50" and ran my spacers would that be okay?
post #6 of 26 (permalink) Old 04-11-2019, 08:17 AM
E.J.'s Avatar
Quoted: 48 Post(s)
No, your 1.5" thick spacer actually lifts the truck 3 inches, adding another 1.5" of lift from the Bilsteins will put you at 4.5" of lift. 3 inches of lift is max with stock arms.
2005 Nismo CC 4x4
E.J. is offline
post #7 of 26 (permalink) Old 04-11-2019, 11:04 AM
Michael Dickenson's Avatar
Quoted: 5 Post(s)
I think his question, or at least mine, would be what would the 5100's need to be set at when using the 3 inch spacers? Just set the 5100's to what would otherwise be their stock (no lift)?
I understand 3 inches is the max. So alternatively, would it be better to use the 5100's set to 3 inches with no spacer?
Sent from my SM-N960U using Tapatalk
Michael Dickenson is offline
post #8 of 26 (permalink) Old 04-11-2019, 12:12 PM
Quoted: 990 Post(s)
If you run that spacer you will have some bad stuff going on. No down travel would not only be harsh but potentially damaging. You will get major shock crush, and need to run a taller bump stop to limit the already limited suspension travel. You have a total of 5.5" of suspension travel. In stock form it is set about 2" up and 3" down. Lift comes from this 3" of down travel. At 3" of lift, you have no down travel. You can not gain anymore lift past 3".
Just set the 5100 at 2" and call it a day. If you want more, get some aftermarket upper control arms. This can yeild you a total of 7.5" of suspension travel. Then add a 1.5" lift spacer (3/4" thick) and that is about the most lift you will be able to get with your truck, unless you add a drop bracket, titan swap or a body lift.
06 KC NISMO 4x4 6sp
post #9 of 26 (permalink) Old 04-11-2019, 12:56 PM
whistler's Avatar
Quoted: 1089 Post(s)
That is correct. That is called the “motion https://en.m.wikipedia.org/wiki/Motion_ratio
whistler is offline
post #10 of 26 (permalink) Old 04-11-2019, 03:57 PM
obrianmcc's Avatar
Quoted: 60 Post(s)
5100's max out at 2"... you could possibly run a 1/4 - 1/2" spacer with a max lift of 3", however at that point you really should replace the UCA's
2014 Pro-4 Crew
obrianmcc is offline
Similar Threads
2009 lift with 5100 bilstein shocks, 2" spacer in front and 2"5 blocks in back Anthony123 New Member Introductions 1 04-26-2018 06:36 PM
*UPDATED* Suspension Lifts and Body Lifts for 2005+ *PLEASE READ BEFORE POSTING HERE* JeniorNV Suspension 10 03-22-2018 09:35 AM
Heeeellllppp!! Bilstein 5100 Max Lift Compresses Spring Too Much??? Huskaroo Suspension 16 11-29-2017 08:45 PM
F/T: Bilstein 5100 front&rear+PRG 1/2" spacer, 5125 rear. JSutter Parts 8 08-26-2016 09:28 PM
Potentially New Bilstein Coilover! 6112, a budget minded beefy 5100 glamisdude Suspension 58 02-01-2016 04:11 PM
