Truck Bed Rack - Nissan Frontier Forum
post #1 of 9 (permalink) Old 04-11-2019, 01:00 PM Thread Starter
Truck Bed Rack
Aloha folks, just wanted to get some suggestions/feedback! I want to build a truck bed rack for my 12 Crew Cab SV. I was wondering the following:
1. Steel tube or steel pipe?
2. Should I pick up a tube or pipe bender and do it myself or pay for it to be done? Approximately how much would it cost to bend.
Hopefully you can visualize what I'm about to describe.
I want to have 2 bars going across from left side to right side. Going up with a slight bend to match the contour of the cab. I'll have another bar notched into both bars going across that go from the back to the front extending over the forward bar and about half of the cab in a U shape. Welding it all together with angle brackets running the length of the bed on both sides.
Thanks in advance for any questions or assistance!
d1kingofkings is offline
post #2 of 9 (permalink) Old 04-11-2019, 01:16 PM
whistler's Avatar
Quoted: 1085 Post(s)
Tube. Same with bender.
Unless you plan on doing a lot of bending, pay to have it done.
whistler is online now
d1kingofkings (04-11-2019)
post #3 of 9 (permalink) Old 04-11-2019, 01:43 PM Thread Starter
There will be a slight bend on each side to match the cab and a 90į on each side to going across. The bar on top will be a U shape (almost as wide as the truck). How much should I look at spending for a tube bender (there will be a learning curve for me to bend my own)? Or if I pay what do you think it'll run?
Also, I'm looking at 1 1/2" or 2" to match my rails. What thickness should I get? .500? Thinner? Thicker? Thanks again Whistler!
post #4 of 9 (permalink) Old 04-11-2019, 01:50 PM
MNCarl's Avatar
Quoted: 194 Post(s)
I had a metal fabricator , fabricate something like you are describing for my roof top tent , it is designed to bolt to the top of my truck bed allowing me to still use my tonneau cover.
Click here: https://www.clubfrontier.org/forums/f...-moose-228865/
MNCarl is offline
The Following 2 Users Say Thank You to MNCarl For This Useful Post:
d1kingofkings (04-11-2019), whistler (04-11-2019)
post #5 of 9 (permalink) Old 04-11-2019, 01:58 PM Thread Starter
Nice MNCarl! Similar. I don't use a tonneau cover. The rack for me will be a little higher than the cab and extend over it about half way. I like how yours bolts in at each cap. Not sure if I use angle bar and bolt in every thick section of metal if that's overkill or not.
post #6 of 9 (permalink) Old 04-11-2019, 02:03 PM
whistler's Avatar
A decent tube bender( no HF) will be around $500. Plus a single die runs around $200.
You will need a notcher although you can get away with a chop saw and a 4.5 grinder.
Here in southern California , shop rate is $90-$ 120 an hour.
If you you give exact dimensions , location of ends,itwill keep cost down.
post #7 of 9 (permalink) Old 04-11-2019, 02:18 PM
whistler's Avatar
https://pro-tools.com/
This is what I have but I converted to air/ hydraulic , I have five sizes of dies.
Over $3500 investment.
You can calculate bends, angles , locations the old school way but I use a combination of a bending program (Bend Tech) and a design program(Solid Works)
Worth it to me since I do a lot of bending.
If you use DOM, .120 Wall thickness.
ID:	291627   Click image for larger version
ID:	291631   Click image for larger version
ID:	291633   Click image for larger version
The Following 2 Users Say Thank You to whistler For This Useful Post:
d1kingofkings (04-11-2019), JCKeppel (04-11-2019)
post #8 of 9 (permalink) Old 04-11-2019, 03:08 PM Thread Starter
Sick, thanks for all the info Whistler!
The Following User Says Thank You to d1kingofkings For This Useful Post:
post #9 of 9 (permalink) Old 04-15-2019, 12:01 AM
Quoted: 17 Post(s)
I am in the same boat as you are. I have been wanting to build a rack as well and one other material I have been considering is some C channel bar. All you would need to do is notch out section of the c channel, bend and weld. If you google toyota tacom RCI bed rack, it will give you some ideas. Even if you get a shop to bend the tube for you, you would still need to weld some brackets for mounting to the bed side.
e30dean is offline
Similar Threads
Super cool, super custom bed rack setup SVenture Parts 1 11-29-2018 09:53 AM
Looking for a bed rack jamesfast General Discussion 9 06-05-2017 12:08 PM
Aftermarket Bed Rack darnucks Exterior Mods 2 10-21-2016 02:09 PM
Tonneau cover and Over the Bed rack combo murfo General Discussion 0 07-06-2016 09:59 AM
FS Yakima Bed Rack System, Atlanta area Ugafiredawg Parts 1 04-27-2016 12:12 PM
