Qr25de custom intake manifold - Nissan Frontier Forum
post #1 of 6 (permalink) Old 04-15-2019, 04:17 PM Thread Starter
katillidie's Avatar
Quoted: 2 Post(s)
I have this illness.. I can't keep anything stock..especially if I think I can improve on nissans engineering.. even if that's not the case I gotta try... if u search my sn ull see I once had a 98 that I used a few 240sx parts on.. along with attempting to swap a 240sx intake manifold onto the truck.. I was unsuccessful. But at least I tried... so I recently purchased this 2019 4cyl qr25de 2wd frontier... the first thing I noticed was the huge lack of power compared to the 4.0... then I realized part of the problem... nissans engineers completely flopped when designing this horrendous intake manifold.. I don't care what anyone says, there is no way that thing flows to it's full potential... anyway.. I decided I would try to make a setup more to my liking.. in my research of the qr25de I found that the Altima intake was a 2 piece setup.. the lower which is aluminum and the upper which is plastic.. that's where I would start.. i sourced a Altima lower manifold from a local salvage yard for $10, then ordered 4 runners and plenum from xcessive manufacturing.. I decided I wanted to use the vq40de throttle body since its 70mm. So I had my local machine shop make a throttle body adapter.. then just had it all welded together.. not quite sure on fitment yet, but if I relocate the battery, there should be plenty of room once that monstrosity Nissan thinks is a intake manifold is out of the way.. here is the finished manifold... will be doin install soon along with dyno results..
katillidie is offline
post #2 of 6 (permalink) Old 04-15-2019, 04:23 PM
AndysLog's Avatar
Quoted: 1159 Post(s)
Feedback Score: 9 reviews
nice. whats the factory one look like for a comparison?
AndysLog is offline
post #3 of 6 (permalink) Old 04-15-2019, 04:55 PM Thread Starter
katillidie's Avatar
Quoted: 2 Post(s)
Factory intake manifold the runners come out of the head go up and over the valve cover, which places the throttle body above the exhaust manifold. Then the intake pipe and mafs wrap back around to the airbox on intakes side of head...
Name:	4978740770_91f2b59f74 (1)_1555361694911.jpg
post #4 of 6 (permalink) Old 04-16-2019, 06:30 AM
I am a bit sad my 4 cyl doesn't have a stronger mid range. The little engine has a 4" stroke and should have gobs of torque. I'll be curious how shortening the intake runners will have on the mid range driveability.
The work you put into that nice manifold would have been fun if it fit an Eaton M-62 on the side of the engine. Now that would be torque! Of course a new ECU would probably be required for tuning.
Tt
Tomterrific is online now
post #5 of 6 (permalink) Old 04-16-2019, 11:06 AM
Quoted: 17 Post(s)
I'm bettin the factory will out flow your setup by a large margin. yours has to much volume in the runners an plenum,to many 90 degree turns and looks like something off a john deere tractor, but hey at least your having fun.
bajasam is offline
post #6 of 6 (permalink) Old 04-16-2019, 03:46 PM
silverarrow27's Avatar
Quoted: 36 Post(s)
Nice, the design looks like it should net you some decent gains mid to high range power.
2002 Auto Frontier Crew Cab Long Bed 4x4 Supercharged
Mods: None
silverarrow27 is offline
  Nissan Frontier Forum > Nissan Frontier Forums > 4 Banger Lounge
Similar Threads
x_mods truck x_mods 2nd Gen Frontier Builds 970 12-11-2016 06:27 AM
Broken bolt on intake manifold support bracket: fix or leave alone? sippy DIY - Do It Yourself / Tech Tips 5 05-26-2015 11:35 PM
s14 intake manifold swap attempt on my 00 frontier katillidie 1st Gen Hangout 5 04-26-2015 02:08 PM
