Nissan Frontier King Cab Pro-4x, VK swap, 6 speed manual, Titan swap, Etc - Nissan Frontier Forum
post #1 of 5 (permalink) Old 12-20-2018, 06:43 PM Thread Starter
Kudu's Avatar
Quoted: 5 Post(s)
Hey Everyone,
So I recently purchased this truck from Sunny and it is amazing. Unfortunately I borrowed money from some family for it, and they need it back all of a sudden. This was basically my dream rig and I can't believe that I have to do this so quickly. Anyways, full details are below. Located in Denver. Motivated to sell ASAP. Please feel free to cross post this else where. I don't have Facebook but people can link to it there if you know someone who is interested. Just looking to get my money back. $20,000 for a forum member!
2010 Nissan Frontier Pro-4x King cab 4X4 (Gray)
Technology package with Rockford Fosgate and bluetooth.
86,000 original miles
Engine
09 VK56DE V8. Swapped in with 40,000 miles
Driven desire VK swap engine harness
JBA 6400SJT titanium ceramic long tube headers
Cajun stainless resonated cat delete pipes
Cajun stainless Y-pipe
Borla pro XS muffler
Air Raid CAI with pre filter
5523 Motorsports AFR harness extensions
Rugged Rocks high output alternator
CSF aluminum radiator with dual E-fans
Silicone coolant hose kit in green
Odyssey battery with Ballistic fab battery cage.
Uprev tuning
PRG engine mounts
Transmission
Stock original Frontier 6 speed with PRG short throw shifter
Driven desire VK to Frontier 6 speed manual adapter plate
350Z lightweight flywheel
Z-speed 350Z stage 4 track clutch rated for 600TQ
PRG tranny mounts
Suspension, axles and steering
Front:
M205 3-rib front diff, re-geared to 4.56 with ARB air locker, PRG delrin bushings
Radflo 2.5 Titan swap extended length 650# spring in green
CJD Racing fabricated Upper control arms
CJD Racing fabricated Lower control arms with poly bump stops
Dirt King fabricated Titan 4x4 spindles
CJD Racing full heim steering
Welded " coil bucket reinforcement rings
New OEM steering rack with PRG delrin bushings
OEM Titan Cv axles
Extended stainless brake lines
Titan Timken unit bearings 6x5.5 lug pattern
06 Titan calipers (red) with power stop rotors and pads
Rear:
2012 Full width M226 Titan rear axle, re-geared to 4.56 with ARB air locker, relocated fabricated spring perches and shock mounts, Ballistic fab U-bolt flip kit, Ballistic fab M226 diff cover, 4X4 Parts diff skid, Axle breather extension
Bilstein 5100 shocks
OME (Old Man Emu) HD Dakar leaf pack with bushings
Nisstec Adjustable rear lift shackles (green)
06 Titan calipers (red) with power stop rotors, pads and E-brake
Wheels and tires
5- Level 8 MK6, 17x9 with 0 offset, 6x5.5 lug pattern (gunmetal gray)
5- Nitto Ridge Grappler 35X12.5R17
Dyna Beads tire balancing beads
Bumpers and Armor
Front bumper: MOVE DIY bumper. Bumper is highly modified from MOVE's original design for clearance. 2" body lift, Winch mount, LED cube and 10" light bar cut outs, and custom radiator skid plate.
Rear bumper: Hefty fab bumper with wrap around quarter panel protection, Dual swing arms (One for 6x5.5 lug tire carrier and other for 4 gal Rotopak), 2" hitch receiver, Rigid LED flush mount back up lights, bumper built for 2" body lift, black textured powder coat.
Skids: Combination of Shrockworks and Hefty fab skids. Engine, transmission, transfer case, and gas tank.
Rock sliders: White Knuckle off road sliders built for 2" body lift
*Skids and sliders are installed with Four treks Rock washers
Interior
ARB dual air compressor
Green LED dash light swap
Weather Tech floor mats
Cobra 18WXSTII CB W/ fire fly antenna
Heps Design King Cab window Molle panel w/Molle bag
Rear seats and back panel replaced with bedlined plywood for Compressor mounting.
Misc
CJD Racing fabricated grab handles (Oh **** handles)
2" body lift
60" Hi-lift extreme mounted to Heps Design utilitrac mounts
Off Road Gorilla hood struts
Extras
2- Titan width CV's
Set of L and R Stock fenders in Gray
Set of new fender liners
Spare Timken unit bearing
Stock rear interior pieces and jump seats
Box full of random nuts bolts, and other parts.
The truck has 86,000 miles and the only original items on truck are the cab, bed, frame, gas tank, hood, interior, transmission, and transfer case.
Engine, front diff, and rear diff had 40,000 miles on them when installed on truck.
Front and rear diffs have been re-built with new gears and ARB lockers and now have about 6,000 miles on them.
All fluids have been changed within the past 1,000 miles.
Lots of new parts on the engine (spark plugs, valve covers, belts, etc)
All new heim joints and uniballs in upper and lower control arms
The truck has the normal wear and tear. Small dents and scratches which would be expected on an off road truck.
All maintenance is up to date and everything is mechanically fine.
Truck is fairly quiet at idle and cruising speeds, exhaust sounds great when you are on the throttle. Race clutch is louder than a normal one and engagement is real grabby, but drives perfectly fine on and off road.
Truck cannot be built for what I am asking, if you have doubts please feel free to price everything out and add labor if you can't do the work yourself. KBB on truck in stock form is $13,000-$14,000.
Please message me with any questions or interest.
CLEAN COLORADO TITLE IN HAND. MOTIVATED SELLER.
ID:	286229   Click image for larger version
ID:	286231   Click image for larger version
ID:	286233   Click image for larger version
Is that a Suzuki?
Kudu is offline
post #2 of 5 (permalink) Old 01-09-2019, 11:42 AM
Plan B's Avatar
Quoted: 21 Post(s)
Bad-***!
'00 2.4l M/T KC XE.... purchased new sept. 2000... and Driven hard...208K and counting (still have original clutch)
Plan B is offline
post #3 of 5 (permalink) Old 01-09-2019, 11:48 AM Thread Starter
Kudu's Avatar
Quoted: 5 Post(s)
Still for sale believe it or not. Don't know how someone hasn't hopped on it!
Is that a Suzuki?
Kudu is offline
post #4 of 5 (permalink) Old 01-09-2019, 04:53 PM
AndysLog's Avatar
Quoted: 1184 Post(s)
Feedback Score: 9 reviews
WUT.
man thats a bummer, but like why would you borrow money from your family to buy a toyyyyyyy.
thats crazy.
all i can do is sleep easy knowing i would ***** slap anyone in my family asking me for money.
GLWS Man!
AndysLog is online now
post #5 of 5 (permalink) Old 01-09-2019, 05:43 PM Thread Starter
Kudu's Avatar
Quoted: 5 Post(s)
Ha, well the idea was I would be able to pay them back very quickly with the sale of my Equator. It was going to be my work truck as well as weekend play vehicle. Anyway, isn't working out so I need to cut bait!
Is that a Suzuki?
Kudu is offline
Closed Thread
  Nissan Frontier Forum > Classifieds Area > Vehicles
You may post new threads
You may post replies
