M205 4.56 Front Ring & Pinion Gears - Nissan Frontier Forum
post #1 of 1 (permalink) Old 01-08-2016, 05:41 PM Thread Starter
Supporting Vendor
4x4Parts's Avatar
4x4 Parts - Titan 4.56 Front Ring & Pinion Gears DTRP456FTTIT - Your #1 Source for Nissan Aftermarket Parts!
2004 and Newer Titan M205 Axle
SKU: DTRP456FTTIT
Exclusively from Automotive Customizers 4.56 Ring & Pinion for M205 Front axle.
New gears allow for more torque, more accurate speedometer readings and proper engine rpm after installation of new tire size.
Made of 8620 hardened steel. Perfect for swapping in M205 Axle from Nissan Titan. Engineered to be used with the 24 spline pinion flange found on 2007 & newer M205 Front Axles. 2004-2006 M205 Front Axles may need an optional 24 spline flange.
$309.95
Description
Installation Kit is sold separately
Installation Kit includes
Inner Pinion Bearing
Outer Pinion Bearing
Crush Sleeve
2-Carrier Bearings
It is important that you count the pinion flange splines.
Comes with 24 spline pinion
If you have a 29 spline pinion and need a 24 spline flange please select Appropriate Spline Count and Flange in the drop down menu above
Name:	Ring And Pinion Sets1.jpg
4x4parts.com
4x4Parts is offline
  Nissan Frontier Forum > Vendor Member Section > 4x4Parts.com
You may post replies
