ChaosMinionX's Build '13 Pro4X - Nissan Frontier Forum
 3Likes
post #1 of 146 (permalink) Old 02-23-2015, 02:45 PM Thread Starter
ChaosMinionX's Avatar
Quoted: 196 Post(s)
Hey all,
Got a "new to me" '13 Nissan Frontier Pro4X "Metallic Blue" with 9600 miles on her..
Performance Mods:
UpRev Osiris - Cajun tuned by Joe @ CajunBpipes. Highly recommended!
aFe Momentum GT Pro 5R Stage-2 Intake (formerly an Injen PowerFlow Intake)
XTP IMS
Doug Thorley Long Tube Headers
Stillen LightWeight Under Drive Pulley
aFe MACH Force-Xp 2-1/2" to 3" Cat-Back Stainless Steel Exhaust System w/High Tuck Tip
aFe Silver Bullet TBS (I got it cheap!)
Doug Thorley B-pipes with Magnaflow High Flow cats
R1 Concepts Slotted Premium Rotors with Hawk LTS pads.
Stainless Steel Extended Brake lines
4.10 Gears (front and rear)
Suspension Mods:
Titan Swap w/M205
Dirt King UCA
OEM Titan LCA
Extended Heim Outer Tie Rods
Radflo 2.5 Extended Travel with 650# springs
Radflo 2.0 Rear Emulsion
Alcan 3" Leaf Pack w/ Military Wrap and +500lbs
UBolt Flip kit w/ custom mounted 4.5" bump stops
Ballistic Fab Boxed lower shock mounts
Nisstec Adjustable Shackles
Armor:
P&P Engineering Level3 rock sliders
Hefty Fabworks full steel skids
Hefty Fabworks Aluminum front bumper (ordered!)
Exterior Mods:
OEM Hood Deflector
WeatherTech Dark Window Deflectors
OEM "Midnight Edition" Frontier Grille
13" AntennaX Offroad Radio Antenna
Sylvannia ZXE 9007 HL, and Nokya Hyper Yellow H9 fogs
Level8 Tracker Pro 16x8.5 Wheels
315/75/16 Goodyear MTR/K
FormulaOne Pinnacle ceramic tint 35% front, 7-8% tint on rears
Poison Spyder Hood Louver
Interior Mods:
WeatherTech mats w/ custom Pro4X logos (Thanks @NissTier - https://www.clubfrontier.org/forums/f...badges-177194/) (https://www.clubfrontier.org/forums/f...7/#post2315826)
Cobra 29 Nightwatch CB w/ 4' FireStick
OEM 2015 Xterra Navigation Unit (everything works)
Driver and Passenger Paracord Grab Handles
Miscellaneous Mods:
Saikou Michi Oil Catch Can
Derale Atomic Cool 15 Row Auxiliary Transmission Cooler
DIY Grounding Kit with 4AWG wire.
Fluids
AMSOil Signature ATF - Transmission, Transfercase and Powersteering
AMSOil Signature 5w30 w/ AMSOil EA Filter
AMSOil Severe Gear 75w90 (M205) 75w140 (M226)
AMSOil NLGI#2 Grease
Pentosin SuperDOT4 LV Brake Fluid
Here she is when I get her!
I will add some pictures of what I got done so far as I get them.
2/23/15 - Got the exhaust done at Lou's Custom Exhaust in Waltham, MA - Originally I was just going to swap the Y for a magnaflow, and install the Super44.. The guy who did my work pulled me out into the shop and ran an idea by me.. We ended up cutting another inlet into the muffler so that it was Dual-Inlet into single out, this cut the Y-Pipe completely out of the equation, they did a great job and the truck sounds mean! I will get some sound clips as soon as I get it back from having tires put on it.
EXHAUST CLIP!
2/25/2015 - Swapped the stock 265/75/16 BFG Rugged Fails for 265/75/16 BFG All-Terrain T/A KO, about 30k miles left on these tires, they were on my old truck, going to switch to 285/75/16 BFG All-Terrain T/A KO2 when these wear out.
Dirty shot of it, gotta wait for this winter to end before I will be able to give it a good waxing and cleaning..
2/28/2015 - Added new bulbs, went with Sylvannia Silverstar ZXE 9007 for the headlights, and swapped fogs for modified H9 Nokya Hyper Yellows (H9 is 65W vs 55W on H11 which is the default bulb)
Also! Cleaned up shot of her after I got it registered in PA, my wife decided to photobomb the picture.
3/5/2015 - UpRev Osiris! Just waiting on my E-tune now
3/17/2015 - Stillen lightweight under drive pulley installed, and Injen intake cleaned up!
Old: 2009 Nissan Frontier Alert Red SE Crew Cab 4x4 Automatic - TRADED!
New: 2013 Nissan Frontier Metallic Blue Pro4x Crew Cab 4x4 Automatic - Build Thread!
UpRev | Doug Thorley LT Headers | aFe Momentum GT Pro 5R Stage-2 Intake | XTP IMS | Stillen LWUD Pulley | aFe MACH Force-Xp Exhaust | B-pipes w/ High Flow Cats | Vibrant Ultra-Quiet Resonators
ChaosMinionX is offline
The Following User Says Thank You to ChaosMinionX For This Useful Post:
10935 (02-23-2015)
post #2 of 146 (permalink) Old 02-23-2015, 06:23 PM Thread Starter
Quoted: 196 Post(s)
reserved
post #3 of 146 (permalink) Old 03-04-2015, 11:54 AM Thread Starter
Quoted: 196 Post(s)
UpRev Osiris today!
post #4 of 146 (permalink) Old 03-04-2015, 12:03 PM
Administrator
Nomad 13's Avatar
Quoted: 157 Post(s)
You can click on the "Edit" button and add something into that reserved post if you want. We do it fairly frequently when building large threads so someone can't quick post in the middle before we can finish. If not hit me back here and I'll delete it for you along with this one.
2014 Pro-4x CC Graphite Blue Rubicon Edition:
Calmini DB, T-swapped w/ARB locked M205, Viair dual OBA, Radflo 2.5s w/700# springs, Radflo hydro bumps, PRG Titan UCAs, DK LCAs, 35" Toyo MTs on Level 8 Bully Pros, 4:10s, Deaver 6" leaf packs, 28" Radflo ext resi 2.0s, U-bolt flip kit, PRG shackles, Steel DS, BDGT, XTP IMS, Airaid CAI, WRP UD pulley, JBA shorties, Magnaflow 15580, Shrock bumper, sliders and skids, VDF rear bumper, X2O 10 Comp, Factor 55 Flat Link, BTF diff cover, DC 180A alt, 30" LED bar, LED map, lic, cargo and BU lights, Cobra LX 29 cb, 5' Firestik
What's next: VK swap and D60 rear....
Nomad's Next Generation
Nomad's Custom BBQ Build
DB Lifts; The Good The Bad and The Ugly
Nomad 13 is offline
The Following User Says Thank You to Nomad 13 For This Useful Post:
ChaosMinionX (03-04-2015)
post #5 of 146 (permalink) Old 03-05-2015, 01:52 PM Thread Starter
Quoted: 196 Post(s)
Custom Weathertech badges!
Before:
After:
post #6 of 146 (permalink) Old 03-11-2015, 02:20 PM Thread Starter
Quoted: 196 Post(s)
Stillen Lightweight Under Drive pulley en route! Hopefully the starter bump method with a long breaker bar works.
post #7 of 146 (permalink) Old 03-12-2015, 01:54 AM
NissTier's Avatar
Quoted: 28 Post(s)
How are you liking the Uprev tune?
2013 Pro-4x Night Armor CC W/luxury
Extended Travel Radflo and PRG UCAs
1'' Rear shackles, OME CS150R's and PRG 5125's
3.69 gears
Lokka
Bullydog tuned
IMS
White Knuckle sliders
Owner made front recovery points
Hi lift
305/70/16 Mickey T MTZ P3
Probably many mods I am forgetting
Many future plans!
NissTier is offline
post #8 of 146 (permalink) Old 03-12-2015, 07:13 AM Thread Starter
Quoted: 196 Post(s)
We have been having technical difficulties getting the tune up and running on the 2013. The 5 map tune profiles aren't taking hold like they should, the lead dev is looking at the ECU ROM to see if there's something being overlooked. In the end if the 5 map tune doesn't work, I will just settle for a single map with a 93 performance tune.
post #9 of 146 (permalink) Old 03-12-2015, 07:52 AM
mtyler11's Avatar
Quoted: 439 Post(s)
I'm really interested how the UpRev works out, I'm interested in its performance abilities and other possible uses.
mtyler11 is offline
post #10 of 146 (permalink) Old 03-12-2015, 07:14 PM Thread Starter
Quoted: 196 Post(s)
HUGE THANKS to Omar, Chris and Hans at UpRev! They finally got my ECU ROM squared away, and everything is working as it should! Took quite a few ROMs to get it fully squared away, but these guys are top notch when it comes to communication and handling issues promptly.
Based on the service alone, I highly recommend going the UpRev route, it definitely seems to be worth the money, especially looking toward the future of what mods you may add down the road.
Now I get to go out and play around with the truck and get some datalogs to get it fine tuned!
The Following 3 Users Say Thank You to ChaosMinionX For This Useful Post:
invasion08 (03-12-2015), RyanD1966 (06-08-2018), Trash White (03-18-2015)
