Old 07-03-2008, 02:13 AM
Steering wheel swap with Altima
Hey, I was just wondering if anyone on here has tried to swap their Frontier steering wheel with one from an Altima or Maxima. Don't even know if its possible but the reason I ask is because I'm not such a huge fan of the big chunk of material at the 6 o'clock position of our stock wheels. I find that when I'm turning, sometimes I don't get a good grip of the wheel when I grab there. But hey maybe its just me, just thought I'd throw this out there. Thanks.
Old 07-03-2008, 08:18 AM
TruckGal81's Avatar
Send a message via AIM to TruckGal81
I just want a black steering wheel, but still a nissan and one that I can still use my cruise control with... so i'm also wondering if steering wheel swaps are possible with any other nissans...
2007 Silver CC SE 6spd - Lorado tonneau, hitch, Eclipse AVN2210P double din, Pioneer speakers, silver painted center dash, custom seat covers, 350z shift knob and black boot, Calmini 5", 2" front spacers, radflos, Dynomax catback and 285 Terra Grapplers. AAL, blocks, and shackles in the rear. aFe intake, foglights, and pathfinder switch covers. Still to come: xterra roofrack, kenwood sub and amp, sound deaden entire cab, 2" DIY bodylift, sliders, wheels (maybe), fire and ice light strip.
http://profile.myspace.com/index.cfm...ndid=358307623
Old 07-03-2008, 08:06 PM
ScottXGTR's Avatar
you and me both buddy. with a manual trans i often only have one hand on the wheel right in that chunky flat spot. stupid designers.
anyhoo, past nissan generations shared a lot of similarities. the number of splines on the steering column happened to be one of them. steering wheels were interchangeable between a 300zx and a 240 and the hardbody pickups. knowing that, id bet a dollar that nissan still does this. check ebay and see if you can pick up one for cheap and try it out.
Old 07-03-2008, 11:07 PM
Upgraded's Avatar
^^^^ Agreed. I know most hondas of the same years will fit each other. I'm sure nissan is no different. could also see if the clocksprings are interchangeable and even get something with illuminated controls. (why we don't already have this is beyone me).
2007 SE CrewCab LongBed
PRG mini lift, Undercover tonnaue
Old 07-04-2008, 12:42 AM
bake's Avatar
What's a clockspring?
Old 07-04-2008, 10:55 AM
Upgraded's Avatar
Aclockspring is a flat cable that is loosely coiled and cased in plastic. its what makes it possible to run power to all of the air bag and steering wheel buttons while still being able to turn the wheel. I was meaning that you could check the clocksprings from both vehicles to see if the wire count is the same and if the altima one will work, you could use the altima wheen and have the buttons light up.
Here's a pic of a clock spring...
Old 07-04-2008, 03:31 PM
zoomzoom's Avatar
wow.. i always wondered how the connections in the wheel stayed intact when it was turned. I had a completely different theory on how that was done.... i was waaaay off.
Old 07-04-2008, 08:05 PM
Upgraded's Avatar
Well, back when there was only a horn, most just had a simple metal tabs that would make constant contact with a greased metal disc if that makes feel any better.
Old 07-05-2008, 12:11 AM
on my 2000 i used a wheel from a 99 infinity to get cruse and a nicer wheel. it all pluged in to the clockspring with no problem.
Old 07-05-2008, 12:55 AM
Thats great, thanks for all the input everyone.
