Old 06-28-2007, 04:36 PM
stevet47's Avatar
Removed KC rear seats.
So I finally got around to removing the rear seats in my KC, I should have done this loooong ago, it took less than 5minutes, and gives me a ton more storage space.
The next step is going to be removing the big piece of plastic that covers the rear of the cab and has the bump-out for the jack. Then I will cover a piece of plywood with matching fabric and attach that to get rid of the bump-out and make it even flatter for more storage. At the same time I will also be building a floor-box level with the top of the hump that the KC seats folded above. This will give me a perfectly flat floor with a perfectly flat back wall making a lot easier to store large things. the floor will have a hinged lid on either side so I can use the space between the truck floor and the raised flat floor for more storage of small things.
05 Frontier KC Nismo 4x4.
Old 06-28-2007, 06:56 PM
oldMainer's Avatar
I am definitely interested in seeing this project progress as I have been toying around with the same idea. The seats are wasted space for me and I'd much rather have a flat surface where I can put things that I don't want in the bed.
Be sure to keep the pics coming.
'07 KC 4x4 SE 6 spd
Storm Gray; power sun roof; Wheelskin wheel wrap; Pilot driving lights; Piaa 1451 fog lights
Old 06-28-2007, 06:58 PM
silversuper's Avatar
looks like a good project. keep us posted
Richie, i love mozilla
www.linxc.com
2001 silver SC CC
Old 06-28-2007, 10:24 PM
stevet47's Avatar
Progress...
Everything that I removed, minus some small bits and pieces. And obviously I already had the headrests and seats removed.
What it looks like now:
And how I bent my bed by pulling into my garage with my hi-lift mounted vertically. DOH! I also got a little dent above the window next to the 3rd brakelight, I am going to try the dry ice trick and see if it comes out. The grocery store right down the road from me sells dry ice oddly enough!
Any advice on how I can sound deaden that back wall? I was thinking of spraying something like a bedliner on it, but I didn't want all the overspray, maybe rolling it on? Or how about a stick-on mat type deadener, does anyone know of any cheap ones?
More updates will follow in the next couple days...
Old 06-28-2007, 11:32 PM
Send a message via AIM to Newman
Ive got that same black tool box. I love how it has sliders so that you can organize all your stuff.
Old 06-28-2007, 11:41 PM
stevet47's Avatar
Yup, except I've out grown it!
Old 06-29-2007, 07:32 AM
oldMainer's Avatar
I think all sound deadeners are all about the same and some swear by using ice and water shield from Home Depot / Lowe's. I've used Raammat (http://www.raamaudio.com/) before with excellent results.
Here it is in my '99 Dakota (if the attachments load)
'07 KC 4x4 SE 6 spd
Old 07-02-2007, 06:42 AM
Peck's Avatar
Wow, I love this idea! That false bottom would be a great place to hide things out of eyesight. I just took the driver's side reat seat out for a sub install I'm working on. I think I'l go this route after I get a little more that 3 payments under my belt.
2007 King Cab SE 4x4 6-SPD
Volant Intake - Deaver Mini-Pack
Icon 2.5 - Radflo Rear Shocks
Stereo Stuff - 285/75 Nitto Terra Grapplers
KC SlimLites - WeatherTech In-Channel Visor
SHIFT_4x4 is $X$...think about it.
Old 07-02-2007, 09:04 PM
stevet47's Avatar
I made some good progress today, I'll post a pic tonight after I get a little more done.
On Saturday I cut off the bracket that holds the stock jack and jack tools, then sprayed the back wall (avoiding my mounting points) with sound deadener. I did not do this to make the truck any quieter, I only did it to not make the truck any louder, as the stock plastic that I am replacing had some foam mat of the back to reduce sound.
Today I did all the main wood working. It is all 1/2" MDF. I still have to cut the 2 doors that will be in the floor on either side, finish up a couple details, glue/screw and carpet everything.
It is built so that the platform just clears with the seats all the way back (how I always have them) and reclined at whatever angle you want.
I know some of you would have done it with some curves and stuff to make it look nicer, but I wanted it to be as utilitarian as possible to make it as easy as possible to store lots of stuff like coolers, my action packer, etc.
Here are the pics:
That gap isnt poor workmanship, its just because its not glued together yet.
Try fitting a 35gal. Action Packer in your KC without this mod! IMPOSSIBLE!
Old 07-03-2007, 06:25 AM
NismoMobber's Avatar
wow dude thats soo cool! Maybe one day... keep up the good work!
2007 Nismo K/C 4WD AUTO
http://s205.photobucket.com/albums/bb146/corcula/
