Fuse Box Install with Switched Power - Nissan Frontier / Navara Forum
Old 01-23-2013, 04:42 PM
treducks's Avatar
Hi
I need some advice. I'm relatively green when it comes to electrical work so please excuse my ignorance.
I've been searching the forums for the last couple days about wiring a fuse box for adding extra electronics to my truck. I've found plenty of posts about people wiring it directly to the battery for a circuit that's always on, but nothing about wiring it to switched power - I wanted to wire mine so it only worked when the ignition was turned on. I've seen some people go through one of the switched accessories on the existing fuse box but I wanted to avoid that. I figured there had to be a better way, connecting the new fuse box to the battery and using a relay to switch it on/off with the ignition. I did some searching last night and found this diagram.
In this diagram you can see there's 40a relays. I was thinking I wanted to use 80a (with the appropriate gauge wiring) instead as I didn't think 40a was enough for all the stuff I eventually wanted to install (CB, lights, winch etc). Has anyone wired a fuse box in this manner? Is 80a too much? Am I looking at this all wrong?
Any advice is greatly appreciated.
Thanks
Ben
2012 SV V6 4X4 Crew Cab
Build Thread
Old 01-23-2013, 05:42 PM
justin123560's Avatar
What fuse block are you planning on using? If you want it to be switched when you start the truck you may have to run a high amp solenoid that will be triggered as i've seen other people do it. Also you will not be connecting the winch to a fuse block. A winch should be connected to the battery all the other accessories are fine. My fuse block is rated at 100amps and I have a 100amp circuit breaker, so 80 isn't that much.
The diagram you provided will work but to simplify things I personally would rather have a single breaker and a single wire going into the cab to provide power to my fuse block
2011 Crew Cab Luxury PRO-2X Super Black
MODS:
BlueSea System Fuse Block, Uniden PRO520XL CB Radio, 5 FT. FireStik II, Xoskel Light Cage, 4 6" KC Daylighters, 4 DDM Tuning 35w 5000k HIDs, Nismo CAI
The Following 2 Users Say Thank You to justin123560 For This Useful Post:
treducks (01-23-2013), x_mods (01-23-2013)
Old 01-23-2013, 05:45 PM
treducks's Avatar
I have a Blue Sea 5026 ST Blade. Thanks for the info about the solenoid. I'll look into that option.
Build Thread
Old 01-23-2013, 05:54 PM
BlueSea . People use solenoids to trigger high amp power inverter. In your case instead will be powering a fuse block.
When tapping into the stock electrical system do not splice or any of that stuff into an existing wire. Just use a fuse tap that will trigger the solenoid. The less you tamper with the stock electrical system the less problems and easy diagnosis. Keep us updates people might want to copy this and its a great idea.
You can mount the fuse block here like this
Installed fuse block, circuit breaker, cb radio
MODS:
Old 01-23-2013, 06:04 PM
treducks's Avatar
Thanks for the info and that link. I was originally going to mount the block under the hood but looking at the photos on that write up, having it behind the glove box may make it easier to wire additional accessories in the future. Currently researching the solenoid route and I'll do a write up once I have it sorted.
Thanks!
Build Thread
Old 01-23-2013, 06:51 PM
glamisdude72000's Avatar
Diagram looks good, but I agree with Justin. Go with a solenoid(s) vs. relays. Just keep the amount of amps in mind when you start adding your goods
2007 KC NISMO-4X Auto Jan 2013 TOTM Desert Camping Truck Round 2
2005 KC SE Auto 4x2 Totaled, missed, loved Desert Camping Truck Round 1
Comprehensive DIY Audio Research/Install Guide
The Following 2 Users Say Thank You to glamisdude72000 For This Useful Post:
Old 01-23-2013, 07:31 PM
30A Block
If you don't happen to need any more than 30Amps of service, this is the way to go...! FUZEBLOCKS.COM
