How about a daytime picture of the lotek double gauge pod above the radio? Their website doesn't show one, ditto for Xterra. I've read the fit/finish isn't great, just wanted to see how yours turned out.
Okay, ill get one when i get out of work. I ordered the "Tan" one off their website and it was so far off on color i had to buy some spray paint to match it a little better, i still need a darker color. It fits pretty well, it just needs the bottom trimmed a little to sit more flush and i just never got around to doing it. Ill look through my phone and see if i have a day time picture
Cool, got a Q ? For u... I want to monitor my tranny & rear end temp. I tried searching for the gauges that r labeled as so but no luck, do they only have the oil temp ones ? Also, maybe ill just buy a set of those cause the $ is good & they look very nice in ur set up ill just have to label them my self somehow. Maybe open up the gauge & label it with a white labeler... Would I have to drill into my tranny & rear end ? Not sure but I guess ill figure it out once I have all parts. Thanks
Ready lift kit 3" / rear leaf spring added lift 2"
Bilstein shocks added 2" up front
cross drilled / slotted rotors / Hood air vent
Aries chrome 3" bull bar / 3" chrome side steps
KMC XD Rockstars 20" black
Toyo open country M/T 33X12.50
8000K HID headlamps 8000K HID fog lamps
5" PIAA ION yellow fog lamps 4 bull bar
Pioneer AVIC D3 DVD double din Navi sys
kicker sound system, 6X9 front doors
6.5 rear doors, 10" Kicker woofer under
rear seat powered by Kicker Amp, wiring kit
Super chips Cortex Power Programmer
oem tow bar installed w/ 8 pin plug
Tekonsha brake control unit
Amsoil 75W90 differential fluid replaced
Hellwig rear sway bar sys / K&N air intake system
E Z Down tail gate / Mesh wire grill Rockstar
If you want tranny temp, there should be a test port you could thread a sensor into. The bully dog wont monitor that stuff theres no factory sensors for it to read. Same goes for the rear end. GlowShift (Which is what i have) and autometer makes very good trans temp and rear end temp gauges (That are labeled properly. PPE is another good gauge brand but you end up spending 300+ per gauge which is ridiculous
Yeah I think id rather get the glowshift gauges & label them myself rather than pay $300 + im sure it van bbdone with a lil creativity. Ill look at my tranny & rear end today after work... So inorder to have al these gauges I must have a bullydog programmer or can I just have them w/o only to monitor ? I am currently running a cortex super chip programmer but honestly I like the bullydog cause of the screen & how it stays set up n can play with it as u have it set up. Looks awsome & im sure its worth it
No no, you dont need a bully dog to have the analog gauges. you just wire the gauges in separate, you dont need the monitor
