FIRST Pillar Mount Bully Dog Tuner and Gauges with Dash Pod :)
A week ago, ordered a bully dog GT triple dog programer, lotek gauge pods for above the radio, and two pod pill. Air/ fuel ratio gauge, oil temp, and vacuum gauge from Glowshift. ( i only went with the 7 color series to keep costs low since im a poor high school kid...) Ill post pictures from the install later, but heres the finish product!
Wiring the gauges for easy for me. But, i can see that if you dont know what your doing or what wires to tap into, youre gonna have a hard time. Just gotta remember you need two hot wires (constant, and a switched) and a good ground. Then the sensor wire. Took me about five hours to wire everything completely and correctly. With inline fuses of course.
Great job! I would love to see this install with day time pictures if at all possible. I am about to buy my Bully dog programmer, and I am interested in a single gauge pod mount if they have one. If not, I will just stick a engine temp gauge in the second port.
CPS
__________________ 2005 NISMO CC 4X2---Bassani Stainless Cat Back, Injen Cold Air Intake, TFU Custom Motor Mounts, P265/75R16 Michelin LTX M/S 2, Stillen Differential Cover, Custom center console mod, Custom skid plate with larger oil filter access panel (diamond plate), LED conversion (all lights), TB Coolant Bypass, Trans. Radiator Cooler Bypass, Transmission Temperature Gauge install, Differential Breather relocation mod (behind passenger tail light)
Ready lift kit 3" / rear leaf spring added lift 2"
Bilstein shocks added 2" up front
cross drilled / slotted rotors / Hood air vent
Aries chrome 3" bull bar / 3" chrome side steps
KMC XD Rockstars 20" black
Toyo open country M/T 33X12.50
8000K HID headlamps 8000K HID fog lamps
5" PIAA ION yellow fog lamps 4 bull bar
Pioneer AVIC D3 DVD double din Navi sys
kicker sound system, 6X9 front doors
6.5 rear doors, 10" Kicker woofer under
rear seat powered by Kicker Amp, wiring kit
Super chips Cortex Power Programmer
oem tow bar installed w/ 8 pin plug
Tekonsha brake control unit
Amsoil 75W90 differential fluid replaced
Hellwig rear sway bar sys / K&N air intake system
E Z Down tail gate / Mesh wire grill Rockstar
It's been in for about 6 months or so. I must say i love it. It's nice seeing what everything on the motor is doing at a glance. I still need somewhere to put the oil temp sensor i havent figured that out yet
