  #21 (permalink)
Old 09-03-2007, 09:04 PM
NismoCC's Avatar
...more...
Let me know if you have any questions about any of the pics.
2007 Nissan Frontier Nismo CC 4x4: 33 in. BFG MT KM2s, 3 in. Calmini Spacers, 3 in. Deaver AALs, Bilstein 5125s, Shrockworks Skids, Cobra 75 WXST CB, Wilson CB Antenna, Penski Custom Sliders, Penski Hi-Lift Jack Mount, 2° Timing Advance, K&N, Air Box Modification, Custom Arizona Pin Striping
Offroad Nissans of Arizona
  #22 (permalink)
Old 09-03-2007, 10:06 PM
Pics of the antenna install?
2007 G35 Sport 6MT
  #23 (permalink)
Old 09-27-2007, 02:22 AM
I have one of those Midland 75 CBs. With an extenal antenna it is as good as any other CB. Don't bother using the rubber ducky antenna unless you're using it as a handheld with the battery pack, and you're using it away from the vehicle. Another advantage of the Midland is that there is no "box" to install. I believe the Cobra has a "box" that needs to be mounted somewhere.
  #24 (permalink)
Old 09-27-2007, 10:28 AM
07Frontier's Avatar
Shift_Just a Mod
Yeah, but that "box" is small and can be mounted just about anywhere (I mounted mine about the foot rest on the drivers side - hidden and out of the way). Both are good CB's. You will just have to decide which one works best for your situation and go with it.
  #25 (permalink)
Old 11-27-2007, 12:00 AM
good info here i am looking at buying the cobra 75wxst also i have a wison antenna already its a wilson 1000
  #26 (permalink)
Old 11-27-2007, 12:55 AM
NismoCC's Avatar
If you are gonna buy one read this thread and PM me if you are interested:
Need a CB or GPS?
  #27 (permalink)
Old 01-28-2008, 05:59 PM
RaginRabbi's Avatar
Moderator
Need CB advice...
Why should I go with a All-in-the-handset unit like the Cobra 75. I guess I just remember using the old base unit style. I don't know enough about the new CB's to know the benefits.
I'm also planning to use a long whip drilled into the metal KMA bumper that I have on order. Is this a bad idea that I should abandon in favor of a magnet on the roof? If that is the case, then I wonder if the CC has the small fresh air vent behind the drivers side rear seat.
2006 Nissan Frontier Crew Cab nismo 4x4 - "EVIL ANGEL" (Nismo CAI, Flowmaster 50-series Exhaust, KMA Wincher Front Bumper, Badland Bumpers Rock Sliders, Summit (T-max) 9K winch, Bakflip G2 Tonneau, AMI Antenna)
  #28 (permalink)
Old 01-28-2008, 07:07 PM
NismoCC's Avatar
Well, most people go with the all in handset 75 WXST because it is nice and small, fits well in our trucks, and can be removed to the point where someone wouldn't even know that you have a CB installed if they didn't look under the dash. Other than that each have their small benefits either way...
As for the antenna you are using, that would be a good location to mount. But it also depends on what you want out of your set up. If you are going for max distance and performance then I would recommend mounting the antenna on the roof. The thing I like about my mag mount is that I can remove the steel whip in about 30 seconds when ever I need (like this weekend when I took a friend to the airport). With the antenna mounted on your bumper you will get the greatest distance across the hood in the direction of the most surface area of the hood, since this will become a ground plane for the antenna. That being said, if you are only using the CB for trail runs and communicating with other trucks on the trail, really anywhere would work for a antenna mount. But I do have to say that it is nice being able to reach out and touch some one that is nearly 8-10 miles away. hehe
The CC has the fresh air vent that I was referring to. Check out my write up if you haven't seen it yet:
CB Install Write-up
The Following User Says Thank You to NismoCC For This Useful Post:
RaginRabbi (01-28-2008)
  #29 (permalink)
Old 02-13-2008, 04:52 PM
RaginRabbi's Avatar
Moderator
So I gave my wife a list of gift options for my upcoming birthday, with one of them being the midland 75 being sold from Target. A few days later I noticed a charge to Target.com for about $100. I guess I know what I'm getting from her. I hope some one else gets me the wireless backup camera and or the gamestop gift card. or even some lift components. The $500 T-max winch is still in the dream gift category.
  #30 (permalink)
Old 02-13-2008, 05:27 PM
NismoCC's Avatar
Yea that is a good radio. I perfer the Corba 75 WXST, but Midland makes some good stuff. You have a much cooler Target than I do, here they just sell the cheap FRS radios. Make sure you post up some pics of your install when you get it done. FYI: The Midland 75 can be installed pretty much the same way I installed mine. What antenna are you going with?
