Aux input install for radio - Nissan Frontier Forum
post #1 of 13 (permalink) Old 01-23-2011, 09:36 PM Thread Starter
lee356's Avatar
Has anyone ever installed a aux input jack in the space above the power jack on a 2009 SE. i know some models came with it already but mine didnt. there is a cap that can be removed and i want to put one on. Do i have to get a different radio or is there a place to install it on mine?
lee356 is offline
post #2 of 13 (permalink) Old 01-23-2011, 11:08 PM
NCFronty's Avatar
Quoted: 29 Post(s)
Feedback Score: 7 reviews
Here is a link to the USB cable--> Coaxial, Cable, Connector, USB, Adapter, Antenna, Amplifier, Enclosure - www.L-com.com
Here is the snap ring around the outlet--> Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
and since there is not really a picture with the snap ring on the Courtesy link here is a pic
Name:	cigarette lighter cover.jpg
2006 Frontier CC 4x4 LE NISMO SPORT Stormgray -
Performance: Airaid Quickfit CAI w/AEM dry filter, XTP I.M.S., 2* Advance,TB Screen mod, Doug Thorley catback, SuperChips Cortex, JBA Headers
Exterior: OEM steps, Nissan hood guard, Morrimoto HID Retrofit D2S, Black Bullet BullBar, Totron offroad LED lights, Hidden Hitch, Nismo skidplates, Extang tonneau,custom Thule rack/wind deflector,Billet Grill
Interior: Pioneer AVIC-8100NEX Navi, Blue LED Gauges
Suspension: PRG Advanced 4WD 2.5" lift w/TC UCAs & 4x Radflos, 1" DIY BL, Susp. Connect. Titan Sway bar bushings
Wheels/Tires: American Outlaw Buckshot 17x9 wheels, Dick Cepek Fun Country II tires
Other: McMaster-Carr Hood lift,
NCFronty is offline
post #3 of 13 (permalink) Old 01-24-2011, 12:35 PM
I didn't want to give up my second power outlet - so I used an RF modulated kit from Scosche to add an aux input:
Scosche FM-MOD02 Play your iPod®, satellite radio, or portable music player through any car's FM radio at Crutchfield.com
It works very well - bought 2 of them actually and been very happy with them.
06 Frontier Crew Cab / 95 SAS Pathfinder
Rowdy_Canuck is offline
post #4 of 13 (permalink) Old 01-24-2011, 12:46 PM
StormFrontier's Avatar
In my opinion, RF modulators suck. There's so much audio quality loss in them, I don't think they're worth it.
To the OP: there's probably a few ways to go here, depending highly on your knowledge of simple circuits, handiness with taking things apart and putting them back together correctly, and how big your cajones are:
1. Open up your existing radio and see if one of the PCB's has a spot to solder in an aux plug.
2. Buy an aftermarket radio which has the aux (or even USB) plug.
3. Buy another stock radio, and perform option #1 just in case you f it up.
Nissan has used so many models of stereo headunits in the 2nd gen Frontier, it's not even funny. It's hard to keep track of what model is capable of what. There's two things to look for. Like I said in option #1, some of the headunits actually had spots where you could solder an auxiliary input in. They're usually screenprinted with an "aux" and "L+ and L- or R+ and R-". Here you can solder in a 3.5mm headphone jack, then just solder in switched power to the aux circuit, since there is a digital volume IC that switches between the radio functions.
The other thing that you can do (as some Navara owners have found), is that you can clip the AM radio input from that digital volume IC, and replace the AM radio inputs with you left and right AUX inputs. Then you'd just have to switch to "AM Radio" as your setting, which in reality would be your MP3 player or whatever. (With this option, you'd lose your AM radio.)
<-Old truck. Now have a 2012 Xterra Pro-4X
Jordan, ME (EIT)
SmugMug Frontier Pics
2008 Storm Gray SE CC 4x4 6spd
See my garage for list of mods.
StormFrontier is offline
post #5 of 13 (permalink) Old 02-09-2011, 10:08 PM
Stormfrontier,
You are describing exactly what I want to do. I am looking at the circuit board on my radio and don't see an AUX input anywhere, neither top or bottom. So, I guess that leaves me with the AM option. I'm having trouble identifying the AM section to tap into. Do you know what it's labeled, or where it is? Thanks for your input. Its has already been a big help.
zenderi is offline
post #6 of 13 (permalink) Old 02-09-2011, 10:29 PM Thread Starter
lee356's Avatar
I don't know how my truck can have a aftermarket radio. It looks like it would have to be custom built.
lee356 is offline
post #7 of 13 (permalink) Old 02-10-2011, 08:21 AM
I found some answers to my question last night, so I'm working on that, but as to your problem, I think you need what they call a 'double din' size radio. Vehicles either have a single din, din and 1/2, or double din. Our vehicles have the double din size. If you look at most aftermarket radios, they are just regular size, which is single din. You can still get one of these if you want. They are half the size (height) of the opening in our vehicles. The installation kit that comes with it will leave you with the radio on top and a shelf under it. I've installed this in a vehicle I used to own. It's is pretty nice. I think I would rather have that than an aftermarket double din size because to me, aftermarket radios can be rather flashy when compared to factory, and I like non-flashy. I want things to blend in. An aftermarket double din size radio is just more flashy than a single din size. IMO.
zenderi is offline
post #8 of 13 (permalink) Old 02-10-2011, 12:49 PM
Nissan4Life's Avatar
Quoted: 450 Post(s)
I found that the cheap FM modulators do not work well. But, if you are using an ipod the cig lighter powered ones that plug into the bottom plug of the ipod works well. I beleive it is two fold. One with the 12 volt it boast the signal and you are not relying only on the weak signal coming from teh ear phone jack. the second reason is the bottm plug. The 3.5 mm ear phone jack puts out a powered analog signal. But the bottom plug puts out a digiatal signal, there are no loses in signal quality till the radio receives it.
Belkin TuneCast Auto with ClearScan for iPhone and iPod - Digital player FM transmitter / charger for car
The stock upgraded rockford fosgate stereo did not have a aux input for the early years05-07 (?) but the later years it had one. Here is a write up on how someone added one.
Aux-in for OEM radio (nissan)
If you have a aftermarket, the easiest way is jsut to get a new aftermaret with an input.
06 KC NISMO 4x4 6sp
Nissan4Life is offline
post #9 of 13 (permalink) Old 02-10-2011, 03:15 PM
thanks. That second link looks more like what I would be interested in. I've been gathering more and more info and I'm about ready to make the modification. If I screw it up, then I'll get an aftermarket radio. It's worth a shot, though. One thing that I learned in that thread was that the cd changer had an aux input on his. I haven't dissasembled my cd changer. On the radio circuit board, I found some unused inputs for a entertainment system, likely for a Pathfinder. There is a DVDON, FES.R+, FES.R-, FES.L+, and FES.L-. My plan is to tie the audio line into the L+R points and power to the DVDON. Shouldn't be too difficult. I'm thinking that when I do that, it will initialize the DVD option on the head unit, which will actually be my new aux input.
zenderi is offline
post #10 of 13 (permalink) Old 02-10-2011, 03:19 PM
Let me know if it works out for you. I'm curious to see if this will work.
P.S. What year is your Frontier?
Jordan, ME (EIT)
