Remotez4Less has great customer service. They actually sent me a DOA unit at first, but prompty sent out a replacement after my return was received. I was able to program the lock/unlock buttons the day I got the key in the mail, but had to take it to my dealer to get it cut/activated for the truck.
I too, had typical experience at the dealer, "you know this is a Rogue key, I can't guarantee it will work..." They charged me $60 to program it.
so for $100, I have a trick key. Money well spent.
yes; when you take your ride in to get the new key programmed, you have to take all keys and key fobs so they can get everything setup. When you leave, all keys work like before, you just have a trick new one in the ignition!
I'd be curious to find out what the range on the remote is. The range on my stock one was terrible and the after-market alarm remote isn't too much better. The one on my Benz was even worse, drives me nuts. Never thought about the bulkiness though. For $100 I have too many other mods to work on.
Range is about the same. There was a thread in the DIY section on how to increase range. I probably wouldn't have done this mod had I not lost a set of keys. Now I'm planning on doing for my wife's X, so no actual fob.
I found the range to be noticeably longer, but is probably due to a new unit with a new battery; I bought my '06 Frontier in 2010, so it was 4 years old when i got it, and I'm sure so were the fob batteries.
I love that I don't have the stupid transponder to deal with.
Just a reminder, get your keys checked for the transponder by and outside source before going to Nissan and paying the ridiculous money. Many tucks don't even have them
Cool mod. I personally would rather have the Intelikey that is in the SL Rogue an Altimas and what not. That thing is sweet. Leave your keys in your pocket and never have to take them out.
FYI - If you purchase a genuine OEM Nissan Rogue key, it comes with a transponder chip. Just need to program it, cut key and then link fob to vehicle.
BTW, $2 to cut my key.
I did the same thing.... but save yourself the $60-80 programming and take the all black valet key that you'll never use and you can split it open and put that transponder in the Rouge key. Works perfectly.
I would not mind doing this mod except for one thing, my wife drives a new Rogue and I already have a Rogue key on my chain. It would be too much of a hassle.
I just ordered 2 OEM Rogue keys off of Ebay. Does anyone have the "lock/unlock/Panic" programming instructions? I plan on taking them to the dealer for the chip programming, but I figured I do the other step myself.
I got both of my Rogue keys today and had them cut by my local locksmith ($10) for both keys. I programmed the remotes in about 5 minutes myself. I did not have my locksmith program the Rogue keys as I just took the transponder chips out of 2 of my old keys and put them into the new Rogue keys. I saved $65 by doing this swap.
Also, I ordered my 2 keys from Keygirl2009 on Ebay and these keys are factory OEM Nissan keys. My local locksmith told me before hand that "if the Ebay keys have any steel in them, I will not cut them". He is referring to the cheap China made key blanks are coming over with steel mixed into the brass causing the $110 cutting wheels on the key cutter to break or dull quickly. So, with this being said, my 2 keys were solid brass with a nickel coating, so he cut them with no problems.
