Recently Ive started adding a lot of electronics to my truck and plan on wiring in some lights, CB, radio accessories that require full time power and other crap in the next few months... currently I have a 10Ga power wire leading from the battery to my amp (small gauge i know but it came with the amp/sub fused of course)...
now my question is... for these components... how do I add a hot power wire that is on all the time to the interior cab of my truck... as well as an accessory wire that turns on when the key is in ACC mode? thanks in advance peoples! and if this has been covered, shame on me... I did a quick search and don't recall anyone ever posting about it...
2006 Super Black NISMO CC 4x2 ![]() Lift: 4" CST spindles, PRG adjustable shackle, Extended front brake lines Performance: Volant Cold Air Intake Exterior: 9 inch black stubbie antenna, Black Carriage works billet grille, borla SS muffler, sweet stickers Interior: Avic f-90BT, MTX powered Subwoofer enclosure, Alpine speakers. Red L.E.D. dome lights, pathfinder switch covers, bling bling interior lights. PS3 GamerTag - Death_By_Stereo
yeah, well I understand that, i'm talking about several different accessories... and I don't have them all right now... i'm just trying to figure out if maybe i can run about power wire into the cab that i can tap in to with several different accessories and i understand that it's going to need to be fused but i can always change fuses depending on what accessories I tap into it...
Probably the easiest switched source to tap into would be the upper 12V socket. But I would only use that to fire a relay. Run a signal wire from the 12V socket back to a box in the engine compartment with a 6 blade fuse block (autozone $6) and a relay (autozone $3) to supply power to the fuse block directly from the battery. you can fuse the fuse block, but its probably overkil lol. then run the your always on power directly from the battery.
![]() 1994 Pathfinder SE 4A 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 10-08-2008 at 05:36 AM. |
Better to dedicate individual leads to individual needs.
2006 4x4 SE Crew Cab, 6 speed, Sunroof - Red Alert/ 2006 Altima SE-R Loaded - Super Black Click here for modifications and pics. My write ups/modifications threads: Alternate tweeter location / stereo install synopsis (PICS!) Custom fiberglass enclosure is finally FINISHED !! ToddG's upgrades/mods (with pics!) |
still unclear on what your load needs are...
as said before swappin' fuses isn't a good thing. i.e. if you run a block w/4 fuses @ 20 amps from a battery lead rated @ 60-30amps. (longer lead = lower rating) do the math. Aux. power sockets could run CB, scanner, Q-beam, coffee maker etc. and could be hardwired. (if the truck has aux. audio input the plug is taped to the harness in back) additional power can be had from the trailer brake controller harness. (if you have 1 and not using it) Factory fused and load rated sources.
2/08 prod. Borla-Energy Suspension-Escort-Hella-Hellwig-Madico-NISMO-Piaa-RAZO-Royal Purple-Shrockworks-Truxx-UNGO/DEI-Wheeladapter-WhiteRhino
I like your idea of using a relay off the top plug because it only comes on when the key is turned... I think this is the route i'm going to go... I think this solution will be a lot easier to troubleshoot if I have problems (i.e. losing power to an accessory) and will be pretty safe. P.S. I know I sound like a total danger to myself, however i'm always really good about soldering and I liquid tape/electric tape the hell out of everything and am really anal about my wires being managed very neatly... P.S.S. this is a short list of coming accessories... 1. CB (cobra 75) 2. Interior accessory lights (L.E.D's) 3. 2-3 Hella lights on front bumper (in the distant future) 4. "puddle" lights along the cab of my truck (activated by a relay attached to cargo light)
^ your avg. $5 SPST relay is max. rated @ 30/40amps. I wouldn't run max. load on one tho'.
Good Luck on the project!
You can run a larger gauge wire from the battery into the cab and use an aftermarket fuse block to distribute power to you stuff. Most auto stores sell fuse blocks with a relay built in that you can hook up to an accessory line to trip the relay and turn enable the fuse block. Should be easy. You could do a seperate fuse block along with that for the stuff you want to have 12v to with the truck off.
White 05 LE crew cab 4x4. Mods so far- Rollbak bed cover, custom Yakima bike rack, Pathfinder center console, Pathfinder window trim, steering wheel audio controls added, vent visors and window tint. |
Run a lower gauge fused wire into the cab (driver footwell) to a fused distribution block inside. I would think it's easier and cleaner to run one wire into the cab rather than several from the block. For the ignition/acc lead, there's one from the ignition harness located at the driver footwell also which is much easier to tap than dismantling the front dash to access the power outlet wire.
edit** ^^beat me to it while i was typing....
11-21 5-29 |
