» Sponsors
» Sponsors
Closed Thread
  #111 (permalink)
Old 04-04-2008, 11:02 PM
toyniss's Avatar
[quote=wperdigon;479906]
there is one thing that is not being discussed -
did you have your side braket supported? i am wondering if the combination of the sharp un chamfered edge and the weight of the manifold on the one side wore back and forth on them - truely no fault of the gasket -[/quot
YOU MEAN THE PLENUM BRACKET THAT SHOULD STILL AT LEAST BE PINCHED DOWN BECAUSE THE WHOLES DONT LINE UP NOW CAUSE IMS?
CALMINI sucks!
  #112 (permalink)
Old 04-04-2008, 11:08 PM
BRUTAL's Avatar
[quote=toyniss;479921]
yes, I think I posted a pic when I did the install thread, mine are still very tight and havent moved a bit.
OMF street-locked Nismo wheels
Shrock skids, winch bumper, 9500# winch.PRG 10 leaf packs, Radflos, TC upper arms.
KN CAI, BFG KM2 305/70/16
Confer roof rack, aluminum tool boxes, Piaa 525 driving/fog, projector HID headlights, and fogs, Carbon fiber grill CF hood, sliders, crossdrilled rotors, EBC pads, 1 touch windows. trans VB modded, modifyed STILLEN SUPER CHARGER, 330 RWHP, NISMO T stat, UPREV http://www.youtube.com/watch?v=Sn1EvGKO1Yo
  #113 (permalink)
Old 04-04-2008, 11:09 PM
Banned
Send a message via AIM to wperdigon
Originally Posted by CT_Nismo View Post
OK Guys.
By now, you will have figured out that I know a thing or two about polymers and how they are manufactured into gaskets. In my very first post on this bizzare incident, I urged the powers to be (Will) to investigate a very strange melting of a polymeric gasket. This was ignored and things got ugly. But now there is a light that seems to point to the truth.
The answer is in the above picture. All the gaskets are packaged in a labeled bag. Each label has a part number. Trace the part number and see if it is right for the application. This is not novel, companies do it every day.
Will, on his part should have kept a list of all materials sent out to his customers. It's called a bill of materials. I doubt this happened. Now he has no way to know what happened. But he has a receipt from gasket manufactuerers. This receipt must have part numbers and he can use this to trace to the truth.
And please, no more talk about a sharp edge causing Up's problem. His gasket melted. If you want to get to the truth, use science and inductive reasoning, not incredulous psuedo-science.
Customers should not due this. It is Will's responsibility as he knows the most about the product. He saw Up's picture. How come he did not pick up on the wrong color? To the extent that Will has abdicated this responsibility, it allowed this Board to speculate, guess, insinuate, and so on. This is bad for business.
The ball is in Will's court, he has the part numbers to trace to the truth.
as you can see here - this is an image taken right from nissan part menu called fast - you can see the part number that is on the detailed description, and then in the menu list, what the part number changes to in nissans ordering system - if you look at the gaskets, you will see it is same exact thing....
we are only using factory gaskets, we never have used anything other than a factory gasket -
also, the gaskets did not melt - stop thinking thats the case here - they are silicone based gaskets, and can withstand over 700 degrees as even while it's crude, we were able to put the gasket in a 500 degree temp for over 30 minutes, and when pulled out, it was still intact and no issues other then discoloring.
see this video...
YouTube - vq40 gasket 500 degrees
  #114 (permalink)
Old 04-04-2008, 11:16 PM
toyniss's Avatar
no one has had to replace the gaskets in plenum right? cause im sure someone had more than 30k on motor before install right?
CALMINI sucks!
  #115 (permalink)
Old 04-04-2008, 11:27 PM
BRUTAL's Avatar
I bought a set in case the orings in the upper plenum need to be changed, I believe i was around 28-30k at the time. Iam over 36k now, they where fine, I reuse orings all the time in Jag intakes as long as theyre not cut, crushed, pinched, or distorted. Very seldom, and theyre $250 a set upper and lower, so I try to save customers money if possible and only have to replace them every now and then. And yes its caught me once or twice, but I know as soon as I start the engine if theres a vacuum leak. And I pull intakes all the time for spark plugs, hoses, oil leaks on cam covers etc.
  #116 (permalink)
Old 04-05-2008, 12:10 AM
the number on my bags/labels are all the same 14032-EA200----IF SOMEONE WANTS TO CHECK.
And It Says Gasket Adapter On The Label.
I Can Just Barely See That Its The Exact Same Number In That Pic.
I can confirm that my gaskets were the same number as listed above, 14032-EA200 and that they were orange in color.
I think we are finally coming to a civilized solution to this situation.
  #117 (permalink)
Old 04-05-2008, 12:35 AM
Mandangalo's Avatar
Originally Posted by agtitan06 View Post
Will, you need to do your dishes.
I kid I kid I joke I joke
at least he has nice feet.....lol
2007 CC LE Injen CAI, Bassani Cat-Back exhaust, Access Vanish Bed Cover, Pioneer Avic Z2 with bluetooth and reverse camera, 55 Watt 4300K HID headlights & Fogs, Ventshade In-Channel Rain Guards, XM Radio
  #118 (permalink)
Old 04-05-2008, 12:38 AM
agtitan06's Avatar
Send a message via AIM to agtitan06
HAHAH, you saw that too?! lol.
  #119 (permalink)
Old 04-05-2008, 12:40 AM
Mandangalo's Avatar
yeah it was great.......he almost burned his toes with a 300 degree gasket....LMAO!!
  #120 (permalink)
Old 04-05-2008, 12:44 AM
andrewcote's Avatar
Is there any way that we could test that while it is under pressure?
i have a feeling that the problem is the sheering, not so much the heat factor.
See you in 2010
Closed Thread
