» Sponsors
» Sponsors
Old 03-24-2010, 01:42 PM
Window controll button not working.
The window control switch on the drivers side that controlls the passenger side window on my "05 is not working properly. Seems like I have to hit it about 20 times to get the window to roll down. And sometimes even taht doesn't work. Gettgin the window back up seems to work fine but I'm just wondering how long it will be before taht starts flaking out as well. I've got 51K on the truck and I guess that would fall under a B2B warranty so I assume it's not covered. Anyone else experiencing problems with their switchs.
Old 03-24-2010, 06:28 PM
chaz's Avatar
get some contact cleaner,comes in a spray can,thats a bad area for water drips coming
from an open window.
Old 03-24-2010, 07:45 PM
Originally Posted by blackwaterstout View Post
The window control switch on the drivers side that controlls the passenger side window on my "05 is not working properly. Seems like I have to hit it about 20 times to get the window to roll down. And sometimes even taht doesn't work. Gettgin the window back up seems to work fine but I'm just wondering how long it will be before taht starts flaking out as well. I've got 51K on the truck and I guess taht woudl fall under a B2B warranty so I assume it's not covered. Anyone else experiencing problems with their switchs. I've heard that Nissans have notoriously bad switches.
I believe you were misinformed. I asked my friend who is a 26 year nissan master tech about this a few minutes ago and he said it's not an item they frequently have go bad. Sure a switch can go bad but they don't fail in large quantities. Now if they get rained on then it's owner related.
Old 03-24-2010, 08:58 PM
Zero Six LE's Avatar
I haven't heard such a thing about Nissan switches. I have an 8+ year old Maxima with ALL of the original switches in perfect working order. My 06 Frontier is the same way.
06 LE KC 4X2 Granite VentureShield extended clear bra, X-pel headlight and fog light shields, 3M A pillar and roof bra, Tekstyle Profile tonneau cover, Carriage Works 4 piece grille, 3M 35% tint, WeaterTech dark side window deflectors, RedLine Tuning QuickLIFT Elite hood lift, Homelink mod, Injen with Asmoil EA air filter, Romik SS Max bars, Nissan iPod interface, Silverstar Ultra headlight bulbs, Garmin Nuvi 755T GPS w/docking station, Dynachrome spring helpers, Gibson SS catback, EC mirror w/temp and compass and a few other bits.
02 Maxima SE Tungsten Blue
Old 03-24-2010, 10:23 PM
His statement will get picked up on a broad interenet search and this is how rumors spread.
I loved my Titan but nonsense posts on those boards fueled all kinds of crap and sales dropped quickly. The Titan is a great truck but forums made to honor it also helps to kill it's image.
The same thing goes for our Frontiers. We are only a fragment of all the owners out there but what we write is what people harp on. Should I have a minor issue here or there I get it fixed and don't post it here as it will hurt more than help. I have on occasion private messaged others to compare notes rather than create a false cause for concern on the threads. I am completely happy with my Nissans.
Old 03-25-2010, 06:03 AM
Roger that
Old 03-25-2010, 10:25 AM
switch removal
Not sure if you know how easy it is to get the switch out. There isn't any need to pull the door panel off.
Put some masking tape on the door handle just below the plastic trim holding the switches to protect it. Take a stiff thin putty knife or butter knife and insert between the two and gently pry it up and the panel will pop up and you will have access to the switch. A new switch is approx. $80.
There are no Nissan gods to appease. What happens is a flurry of reponse posts and people start with the "did you hear the ---- on Frontiers are failing"?
Then you read it on the other brand forums where they poke fun to make it look bad and it grows. Funny thing is their trucks aren't built any better but it hurts Frontier sales which translate into the aftermarket doesn't make things for us.
Heck I just saw a fiberglass shell on a Ridgeline. Think about that most pickup beds are open. Next there are those of us with tonneau covers and last are those with caps. There aren't a whole lot of Ridgelines out there but someone decided it was worth their R&D to create one for it.
If only Nissan got the same respect, as there are more of us than them.
Bottom line is, what is said here has an "end game" result later on.
Old 08-29-2010, 09:56 AM
EB_05_NISMO's Avatar
I get to work and my drivers side window will not roll up. I noticed a small hiccup the other day where I had to press/lift the switch twice or something, but no other warning signs that something would fail.
Passenger side window works fine. I sprayed the switch contacts and plug with contact cleaner, but that did not make it work. Anyone know of anything else I can check, and whether there is a good way to find out if it's the switch or motor? EDIT: After some more searching, it looks like I can swap a working switch with the drivers side one to see if the switch is bad. I'll report back when I get a chance to try that. Other suggestions are welcomed.
ClubFrontier Rules and Guidelines
2005+ Frontier Information (FAQ)
Nissan does not care about it's customers or quality after your standard warranty is up. You should strongly consider this if you plan on purchasing a Nissan.
Old 08-29-2010, 11:46 AM
chaz's Avatar
just test the switch and test the motor,get a decent volt /ohm meter.look for voltage and
test for continuity,then go from there
Old 08-29-2010, 12:19 PM
Well I went out to the truck and figured I'd try the switch again and the window went up. I'll try and test for voltage and continuity when I get a chance to see what may be bad.
