Vibrations? - Page 3 - Nissan Frontier Forum
post #21 of 23 (permalink) Old 10-26-2012, 11:29 PM Thread Starter
jjw1's Avatar
I'm thinking it's the u-joint(s). I've also noticed a vibration when I put the truck in gear. Say I put it in reverse to back up but don't let off the brake there is a vibration. I kind of thought it might be normal but I looked into it and I saw some threads on it and similar cases and all if not most point the u-joints. The vibration around 40-45mpg is not in the steering wheel rather the whole truck like you're on a not so smooth road. I'll have it checked when I get the oil changed.
2011 Nissan Frontier Crew Cab Short Bed SV 4x4
Current Mods: OEM Hood Protector, Vent Shades, Bed Extender, Nismo Rays in the Garage
jjw1 is offline
post #22 of 23 (permalink) Old 11-07-2012, 01:44 AM Thread Starter
jjw1's Avatar
Could it be the torque converter?
jjw1 is offline
post #23 of 23 (permalink) Old 10-07-2013, 04:19 PM
Quoted: 10 Post(s)
I had a vibration around 50-60 mph, thought tires until I rebalanced them myself. I also started hearing a clicking sound at low speeds. After checking my front diff ring for lost teeth I wrapped a tow strap around the front driveline and pulled to correlate the clicking noise to the same spot on the driveline, ie not the pinion bearing as that would move with each revolution. Couldn't feel ANY slop in u joints but it was either that or pinion gear. U joints were cheapest option too at <$9 per joint. Lifetime warrantee were $15 each but not able to be greased as they have synthetic grease, I have a grease gun with amsoil synthetic marine grease already so the cheaper ones will be full of synthetic grease anyway.. Pliers to remove the clips and a large socket and a smaller one and a machinist hammer was all it took. I did remove the driveline from the truck as it's easier to do that way. I also cleaned out the slip joint and greased that with synthetic grease while it was apart. Ended up that only one of the eight u joint bearing cups were bone dry. All the others were greasy! That was causing the vibration and clicking I was having!! Btw the joint had no slop to it like every other bad u joint I've replaced..
2006 Nismo KC 4x4 6speed
Volant CAI with the powercore filter.
Plastic style intake spacer.
Bullydog GT with mild tune.
New ring and pinion and elocker 30Jan15.
Axle vent.
Cargo light always coming on with door open mod
Swapped rear diff with amsoil
Rear pinion went out towing a heavy load so amsoil is out and now some mobil1 75w140 LS synthetic is in!
Swapped front diff with amsoil
Swapped transfer case with amsoil
Swapped 6 speed manual trans with Redline mt85
^sucked so I swapped in royal purple
^sucked almost as bad so I swapped in Nissan mtf which isn't sucking, amsoil next. Nissan MTF is doing very nicely still!!
Added some LED fogs to blind the idiots with drop in hid kits
Notabiker is offline
