vent control valve repair , code P0448 fix - Nissan Frontier Forum
post #1 of 32 (permalink) Old 05-31-2011, 07:06 PM Thread Starter
mr_bungle's Avatar
So. Every once in a while i would get the code P0448 , And a few days ago the gas filler would spit out fuel on the ground . I thought it was because of the body lift i just installed , But it was not , It was the vent control valve. You can see it located near the drivers rear tire on the canister , Which is right next to the rail , Very easy to remove , Just disconnect the wire and the hose . Unhook the clip and then turn to the left , A half turn pull off .
Spray brake cleaner in it both ends . Then spray air in it from a spray gun . And then it was loose again , Before I couldn't get air though it at all . So then I reinstalled it and the code went away. And now it works again and it fills up fine no fuel spilling out .
This worked for me. So if you have the code problem P0448 it may be the vent control valve stuck or dirty , If your fuel is spilling out or slow fill up It may be clogged . You may want to check out the vent control valve
[B]06 NISMO [COLOR=black]nismo CAI custom built amp and box JL audio 10" W3 sub pioneer dvd nav , exhaust . custom tru fire paint applied by me , custom painted rims by myself , tinted rear lights , weathertech floor mats 3" lift by prg 2" body lift by 4x4 parts I am a tattoo artist and i also paint anything you need motorcycles cars boats trucks anything
check me out on facebook under mark sinsel
mr_bungle is offline
The Following 2 Users Say Thank You to mr_bungle For This Useful Post:
Clint (05-31-2011), Nissan_Junkie (10-24-2011)
post #2 of 32 (permalink) Old 08-05-2011, 09:44 PM
NISMOGSXR's Avatar
Now are u revering to evaporation valve or another one? I've had my canister valve replaced twice but still my SEA light comes on n ill clear it it n bout 20 miles later it will come back on. Eveeytime I fill up with gas, it spews out the spout like u say n I want to get it fixed
06 Nissan Frontier NISMO 4x2, K&N air filter
06 Suzuki GSX-R 600, Two Brothers Exhaust, K&N air filter, 520 chain conversion, +2 teeth on rear sprocket
NISMOGSXR is offline
post #3 of 32 (permalink) Old 08-06-2011, 12:07 AM Thread Starter
mr_bungle's Avatar
just try exactly what i did and it should stop it is the valve on the canister on the left take it off and clean it til you can blow thru it
post #4 of 32 (permalink) Old 08-11-2011, 04:15 AM
lumpia's Avatar
Any chance you can take some pics for the slow learning like myself?
lumpia is offline
post #5 of 32 (permalink) Old 08-11-2011, 08:34 AM
ToddG's Avatar
Quoted: 429 Post(s)
Feedback Score: 13 reviews
Yeah pics would put this thread to the next level.
If anybody does this please take pictures and post them here.
My truck will do this every once in a while also.
Seems like it does it more when it's cold out for some reason.
ToddG is offline
post #6 of 32 (permalink) Old 08-11-2011, 10:35 AM
chukb's Avatar
Quoted: 2 Post(s)
I just looked at mine. is it the box thing we are talking about or the smaller round thing next to it?
..................2008 Frontier Crew Cab SE....................
chukb is offline
post #7 of 32 (permalink) Old 08-11-2011, 12:05 PM Thread Starter
mr_bungle's Avatar
here are some pics for you guys
the is right near the driver rear tire on the rail
post #8 of 32 (permalink) Old 09-15-2011, 08:27 PM
I'm gonna give this a shot. My truck has been throwing the P0448 Code for about 2 weeks now. It has also been acting finnicky when refueling. Sometimes it trips the auto shut off on the pump when the truck isn't near full. It'll also burp a bit of fuel as described above.
Current- '13 F-150 FX4 EcoBoost
Previous POS Truck from Hell - '12 SL CC LongBox
Previous - '06 SE CC ShortBox
CdnFrontier is offline
post #9 of 32 (permalink) Old 09-17-2011, 05:13 PM
I checked out my valve today. It was full of fine dust and sand. I cleaned it out best I could with compressed air and brake cleaner. Will report back on whether it fixed the problem or not. For those wondering how difficult this job is....well it isn't. It took all of 15 minutes. I pulled off my rear tire to make it easier to access, it was quite simple. I hope cleaning the valve works.
post #10 of 32 (permalink) Old 09-20-2011, 05:18 PM
SES light back on again after I cleaned the valve. P0048, same code as before. Off to the stealership now...
The Following User Says Thank You to CdnFrontier For This Useful Post:
Jeffmw83 (01-02-2017)
