Trailer turn signal wiring problem - Nissan Frontier Forum
post #1 of 8 (permalink) Old 07-22-2007, 05:37 AM Thread Starter
silvrsled's Avatar
Well, I hooked up the trailer the other day and the left turn signal wasn't working. The one on the truck was working fine so I started to trace it down. Basically, went all the way to the 7 pin connector. No power out of it. Next I went under the truck and checked the connector on the frame. Found the wire for the left turn signal and there was no voltage coming out of it with the signal on. At this point, I'm stumped. I checked the fuse box but there were no turn signal fuses. Has anyone had this problem?
silvrsled is offline
post #2 of 8 (permalink) Old 07-22-2007, 05:13 PM
Frontier2's Avatar
Quoted: 3 Post(s)
Check under your RF kick panel and make sure the tow harness/relays are there.There should be 2 blue,1 brown relays for man. 1 blue,1 brown for auto they should be wrapped up in foam.
06 MAJESTIC BLUE 4X2 LE KC
Frontier2 is offline
post #3 of 8 (permalink) Old 07-22-2007, 11:48 PM
Trailer wiring recall...
Take it to the dealership and they should replace it for free. I did and they did it.
SilverSE05 is offline
post #4 of 8 (permalink) Old 07-22-2007, 11:51 PM Thread Starter
silvrsled's Avatar
I put the tow harness in myself so I definitely know they are there. I do have an extra harness though that I can try out. Thanks!
post #5 of 8 (permalink) Old 07-23-2007, 04:27 AM
dcobb's Avatar
I'm currently having the same problem, or similar one, my left break light / signal for the trailer wiring isn't working. Haven't traced the problem yet, but my break lights on the truck work just fine. Probably loose connection somewhere...
dcobb is offline
post #6 of 8 (permalink) Old 10-07-2007, 03:47 AM Thread Starter
silvrsled's Avatar
Hey, i finally solved my problem. If you look under your driver side dash, is a dual fuse holder with 2 white caps. one of the fuses was burnt out. Replaced it and now it's fine. I'm guessing I must have blown it when I was probing the pins at the hitch connector. Probably shorted out the turnsignal since it's right next to the ground lug.
The Following User Says Thank You to silvrsled For This Useful Post:
DougL (02-23-2016)
post #7 of 8 (permalink) Old 10-07-2007, 12:04 PM
hmontaq's Avatar
I have a similar problem. Uhaul installed it and has a warrenty. They couldnt figure it out so its the stealership for me soon. Glad you got yours figured out.
2005 CC NISMO auto Storm Grey/ NISMO CAI/ Hunter Bull Bar/ Debadged tailgate/ Demudflaped/ CST 4" Spindles w 2" Blocks/ 18x9 Moto Metals 285/60/18 Nitto Desert Tires/ Eclipse 3100 deck, Kicker 45x4 channel amp, 4x651 Polk Audio coax speakers/ Blacked out badgeless grill/ Custom NISMO Offroad fender logos/ Destickered Roof Rack
2006 Sinister DNA
2007 KTM 690 Supermoto
Deckcrafters Skateboards
hmontaq is offline
post #8 of 8 (permalink) Old 10-07-2007, 12:55 PM
Zero Six LE's Avatar
Quoted: 817 Post(s)
Is Uhaul going to pay for the dealer's work?
Zero Six LE is offline
