Not sure if any one can help (just read most of the TPMS threads and no luck) all the tires have 32-34psi its cold out 15-30 degrees but the tire presures are fine and with in what I run normaly. Now I cant get the light to go out. Driving at 20mph for a mile, running erronds all afternoon checking the pressures every time I stoped and they are fine but the light still wont go out. can some one help or direct me to the right thread thanks drew
http://www.clubfrontier.org/forums/456860-post1.html |
![]() ![]() 06 LE KC 4X2 Granite VentureShield extended clear bra, X-pel headlight and fog light shields, 3M A pillar and roof bra, Tekstyle Profile tonneau cover,OEM towing kit w/4 & 7 pin harnesses, Carriage Works 4 piece grille, Covercraft seat covers, 3M 35% tint, WeaterTech dark side window deflectors, RedLine Tuning QuickLIFT Elite hood lift, Homelink mod, Asmoil EA air filter, Romik SS Max bars, Nissan iPod interface, PIAA Xtreme white plus headlight bulbs, hardwired V1 radar locator, Dynachrome spring helpers, Gibson SS catback, EC mirror w/temp and compass and a few other bits. |
thanks chuck I'll try that in the AM
That is silly that Nissan doesn't have a 5th sensor in the spare. My dad's Rav-4 that we keep at our condo has one in the spare, and well... it went off last time we drove it so we filled up the spare.
Do you still have your OEM Wheels? You can check them and see if the sensors are still attached, they are part of the valve stem and visible from inside the wheel. Also, if your new "free" valve stems are rubber, you don't have sensors. Others on here have swapped wheels without swapping the sensors and have not had the alarm go off...
Paul... MODS: OEM Mud Flaps, 255/75-17 Bridgestone H/L Alanza Tires, Edge Evolution Power Programmer, OEM Cargo Management System, Extang Trifecta Tonneau, EGR Bug Deflector, Prodigy Brake Controller, and SuperSprings. Tows my 2008 Flagstaff 29RGS RV! 05 Red NISMO KC, 4X4: SOLD ![]() Get Cash Rebates on your On-Line Purchases! Last edited by 05_NISMO_4X4 : 03-28-2007 at 08:13 AM. Reason: Automerged Doublepost |
I'm starting to have a problem with mine. The light came on and I put 35 psi in each tire and the light went off, then 15 minutes of driving later, the light came on again. Checked the psi again and still at 35 psi???
I'll have to take it in. It was intermittent, but now seems to be permanent. |
I'm glad this is stickied. I took the Frontier up to the mountains this week, and my light came on last night. I checked all the tires and they were fine. But it was cold and I'm guessing that's why the light came on. It came on last night. This morning it was still on until I got out of the mountains and it warmed up (drove about 45 minutes, then it turned off).
2006 CC, SE, 6 Speed Manual, 4X4, V6, Black, Kenwood DDX-7015 with XM, HK Drive & Play, TruxPort |
TPMS light on again in 3 days
My light came on and all tires were fine. Took it to the dealer and they reset it and told me everything looked good. 3 days later it came back on. So tomorrow I will set up an appointment, cause something ain't right.
