Tire Pressure - Nissan Frontier / Navara Forum
Old 02-17-2013, 06:04 PM
Tire Pressure
I'm sure I'm not the first person to post this, but I wasn't quite happy with the ride quality of my new Frontier, even after asking the dealership to align and rotate and balance my tires. It hit me yesterday I should check my tire pressure. It ranged from 41 to 43.5, which is how it came from the dealership.
I took it all down to 40 psi and took it out for a spin. Definitely an improvement! Don't forget to check your tire pressure, even when new.
And I snapped this picture while driving it...
She's getting older... my first new car is not really new anymore. Lol
Have a great day!
2012 Nissan Frontier SV V6 4x4
1985 CJ7 4" Lift/33" Tires
Old 02-17-2013, 06:12 PM
yesterdaysradios's Avatar
Read the sticker in the drivers door jamb. Should show factory advises 35psi. I set mine at 36psi. Stock tires are 44psi. max. Does not need to be anywhere near that, for normal use.
2010 Frontier SE V6 CC LWB, built 04-2010, purchased 07-2010
Current mods: OEM foglight kit, weathertech molded floor mats f/r, locking gas cap, security license plate screws, spare tire chained and master locked to the frame, OEM locking lug nuts, aux input jack w/fm de-modulator, sirius satellite InV 2 radio adapter, OEM mud flaps/splash guards, 2in. round blind spot mirrors, nissan logo valve stem caps, rad/trans cooler bypass, rear axle vent mod, OEM auto dim rearview mirror w/temp & compass, OEM hood protector/bug shield, 35% tint on both front windows and a windshield strip, OEM body side moulding.
Old 02-17-2013, 06:18 PM
invasion08's Avatar
Send a message via AIM to invasion08
44psi is the max psi when the tire is cold. Not when the tire is warm. I set my tires at 38psi. Keep your tire psi where you like.
PRG Basic Suspension Package
XTP IMS, Gibson Exhaust, Airaid Intake, UpRev Tuned
N-Fab Nerf Bars, Bakflip G2, Line X Bed Liner
Old 02-17-2013, 06:20 PM
dan826's Avatar
Have a great day!
Even 40 is still high for stock tires.....
Old 02-17-2013, 07:09 PM
36 is where I run mine also. Yeah, you have to watch the dealer they pump them too high. To the op you might want to drop them down a bit more and have a better ride.
2012 Frontier CC SV 4x2
1971 Plymouth Barracuda
Old 02-17-2013, 07:59 PM
FRONTIER2011's Avatar
Where did you get this info? I thought you are to follow the PSI directions on door jamb no matter what tires you have on it.............
2011 Nissan Frontier SV | Crew Cab Short Bed | 5 Speed 4.0 Liter Automatic
OEM Fog Llights Added | OEM Splash Guards Added | Window Visors Added
Old 02-17-2013, 08:01 PM
Max psi is posted on the tire sidewall. The door jamb info is only a suggestion. Not an absolute. You can run whatever psi you want to, up to the tires max cold psi. The higher psi leads to a bumpy ride (unloaded).
Old 02-17-2013, 08:42 PM
humz's Avatar
Nope those are for stock specs, if you put on a set of 10 ply LT load range E tire in a bigger size your going to want some more air in them.
I don't go much higher though, usually around 40-42 with my 33" MT's.
Alberta Xterra (& frontier) Enthusiasts http://www.thenewx.org/forum/forumdisplay.php?f=82
2010 pro 4x CC - Calmini Rear bumper, 3 fin m205 with cardone titan axles, PRG SAW titan swap pkg with remote res and 650 springs, PRG Shackles, Bilstein 5125 ext travel rear shocks and PRG 2" deaver AAL, 255/85/16 km2's, Hefty Skids and sliders, TJM Portable Air compressor, and 20" Alien LED lightbar.
Next on the list - Shrockworks or Calmini front bumper with winch
Old 02-17-2013, 08:56 PM
EB_05_NISMO's Avatar
I usually add air if I'm towing or hauling.
ClubFrontier Rules and Guidelines
2005+ Frontier Information (FAQ)
Nissan does not care about it's customers or quality after your standard warranty is up. You should strongly consider this if you plan on purchasing a Nissan.
Old 02-17-2013, 09:05 PM
I tow a boat, so I have pumped mine up to 40 PSI. You can see the difference when towing.
2012 SV Crew Cab V6 Auto
