Old 05-13-2008, 12:36 AM
Is there a better sollution for our dipstick?
Just like the topic says..... my OEM dipstick works about as good as a bent nail and looks like one too. I was wondering if there was another VQ-Powered vehicle in the Nissan/ Infiniti lineup I could get one from that isn't bent at a 45 degree 3/4 way to the top. It's almost impossible to get it back in after checking the oil.
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,
but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
"Wow! What a Ride!"
'08 Nissan Frontier SE Crew Cab Long Box 4x4 Avalanche, Steel ,tow pkg, moonroof etc..
Old 05-13-2008, 12:42 AM
Mainerunr's Avatar
-Ryan
dont try to put it in the way it ends up...twist it before you start (cant remember if 90 or 180 degrees is what I found to work best but there is a trick to it.
(sorry if you're on dialup)
(Thanks InYourFace1650)
Also, some 285/75/16's will rub (with stock wheels) with a 2" lift, some will not. (Please stop asking this 6x a week and in every tire thread.)
Old 05-13-2008, 10:06 AM
He is correct in his method. If you try to insert it the way you think it should go you will end up bending it and making it worse. It is a poor design. The old wire type would work better.
2008 Nissan Frontier LE Crew Cab Long Bed 4X4 in Radiant Silver
2007 Nissan Pathfinder SE 4X4 in Desert Stone
Old 05-13-2008, 10:09 AM
toyniss's Avatar
i just insert mine til i feel resistance and turn it a bit and goes right in. sorry your having such trouble with your dipstick!!!!!!!!!!!! haha.
CALMINI sucks!
Old 05-13-2008, 11:30 AM
Send a message via AIM to Rick F
I was going to say, I haven't had any problem with mine. Maybe yours is bent out of shape. Sorry to hear about the complaint.
Old 05-13-2008, 12:18 PM
stevet47's Avatar
Yea.. it is an odd design, but it certainly isn't a hassle, you just kind of twist it and it goes right in. Strange though, that the ATF dipstick is the wire type, and this one isn't.
05 Frontier KC Nismo 4x4.
255/85R16 Maxxis Bighorns, 2.5" PRG lift, Demello Sliders, Shrockworks Engine, Front/Radiator & Gas Tank skids, 15# Ultimate Air CO2, WRP Crank Pulley and IMS, Fujita Intake, Slotted Rotors/EBC Pads, Braided Brake Lines, WRF Lightbar with HID converted Hella 500s.
In the works: Custom re-built leaf springs, custom rear diff cover, u-bolt flip.
Old 05-13-2008, 12:44 PM
try this method...
I just came in from changing my oil. The trick to this is, place the stick in the tube with the finger pull facing the front of the truck and as you push it in about two thirds of the way in it will rotate to it's correct position. I tried it four times and it went in effortlessly. Hope this helps you out.
Old 05-13-2008, 03:40 PM
XE_KING's Avatar
Poor guys got a crooked dipstick.... I believe some of that bend is actually to keep the dipstick from rattling in the tube...
-Nick-
01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod, Optima Yellow Top, Hyper White Headlights, 3" Lift, Rancho 5000's Bumper To Bumper.
Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!!
Old 05-13-2008, 04:26 PM
Originally Posted by Clint View Post
I just came in from changing my oil. The trick to this is, place the stick in the tube with the finger pull facing the front of the truck and as you push it in about two thirds of the way in it will rotate to it's correct position. I tried it four times and if went in effortlessly. Hope this helps you out.
It also works with the pull pointed toward the cab of the truck in the fashion explained above.
Old 05-14-2008, 11:35 PM
rorybellows's Avatar
you gotta use a little english
