Temp gauge bouncing what gives? - Nissan Frontier Forum
post #1 of 10 (permalink) Old 09-01-2007, 08:11 PM Thread Starter
On my lovely trip across Kansas today my temp gauge started bouncing any ideas?
zukicreations is offline
post #2 of 10 (permalink) Old 09-01-2007, 08:36 PM
Zero Six LE's Avatar
Quoted: 874 Post(s)
What were you driving?
Zero Six LE is offline
post #3 of 10 (permalink) Old 09-01-2007, 09:28 PM
Icarus03's Avatar
Have you done anything to the coolant recently?
Air in the coolant system?
- Bomz SRI - Gibson single exhaust - Custom Y-pipe w/ no secondary cats- 350Z antenna -
- Infinity speakers - Wagner trueview headlights - Yellow front 194's - Fog lights w/ prk lights mod
2003 Hyundai Tiburon GT V6 Auto in Silver
- Injen CAI - SSA/Magnaflow dual catback exhaust - lots of random goodies -
Icarus03 is offline
post #4 of 10 (permalink) Old 09-01-2007, 11:55 PM Thread Starter
it's an 01 cc s/c fronty. when I checked it out after it started bouncing, the coolant was only lukewarm. So it's not over heating the question is, will it hurt anything?
post #5 of 10 (permalink) Old 09-01-2007, 11:58 PM
HKYStormFront's Avatar
Quoted: 30 Post(s)
sounds like your radiator might be stopped up... or your water pump is not working properly... just two guesses...
Patrick // 06 KC Nismosis 6 spd Storm Gray
Mods: lots... Uprev tuned: 257whp & 292 ft lbs
09 Pontiac G8 GXP // M6 // Sunroof // Tint... For Now
"I prefer to drive manuals because I prefer to drive, not be driven."
HKYStormFront is offline
post #6 of 10 (permalink) Old 09-02-2007, 12:01 AM Thread Starter
but it's not running hot thats the puzzling part....my thought is that the thermostat failed and is open
and what will it hurt to drive it like that like i did for 150 miles today?
Last edited by zukicreations; 09-02-2007 at 12:37 AM. Reason: Automerged Doublepost
post #7 of 10 (permalink) Old 09-02-2007, 12:55 AM
Kalikikopa's Avatar
Can you describe bouncing? Is it slowly moving up and down like the engine is heating and cooling quickly? If so check the thermostat. Is it going to around normal, then dropping quickly then going back to around normal? if so check the sending unit connection, or the power line going to the gauge. Is it quickly ( like under a second) from top to bottom? If so you may need to check the wire going from the engine all the way to the gauge. The coolant gauge works by providing power to the gauge, then the temp is read by the sending unit adjusting the ground to give you a reading. If that wire is frayed, it could ground out, taking it to a full reading almost immediately. Good luck, Electrical problems are a beast to pinpoint.
2006 4x2 CC SE 6sp
Kalikikopa is offline
post #8 of 10 (permalink) Old 09-02-2007, 01:03 AM Thread Starter
From what else I have found it is the t-stat. So I will be replacing that. It will show normal to on or below C in 3-5 second intervalls. So I guess that needs replaced. Great thing to do on the road, good thing we have friends local. Thank God for friends.
post #9 of 10 (permalink) Old 09-03-2007, 01:09 AM
calimobber's Avatar
Send a message via AIM to calimobber Send a message via Yahoo to calimobber
sounds like maybe a loose connection? the wire could be losing signal or just the sensor bad.
Its only an offroad truck if you take it off the road.
10" Alpine sub/Alpine 400 rms amp, ScanGauge 2, Fog Lights, Clutch bypass switch, Hardwired 400w inverter, Back-up lights, Reverse Lights on/off/norm switch, Shackle Lift with helper Springs.
[U]99 Frontier KC XE 5spd 2wd manual everything
calimobber is offline
post #10 of 10 (permalink) Old 09-05-2007, 12:07 PM
TwoBills's Avatar
I don't think it's the t-stat, unless it's been replaced lately. More than likely it's the sending unit or a wiring problem. I'd start w/the connection. Clean and grease it.
TwoBills is offline
