Old 09-16-2008, 10:38 PM
cvianna's Avatar
ScanGauge II - Heaven and hell
Hello!
My new scangauge II arrived today. Couldnt wait to have a free time to go to the garage and test it. After reading so many good comments about it, I was condemned to buy, hehehe
Very cool thing. Better than expected. BUT...
When I started driving I noticed some odd things in my frontier.
The RPM gauge (the original one) was acting strange. When the RPM was going down, instead of going down easly, the gauge just moved from the 3000 rpm to 1000 rpm in ONE step. The temperature gauge didnt move, indicating a cold engine when it was not.
Worse... making a turn, i have switched the right turn sign. TIC... no tac. No tic-tac. Just one tic. And the green arrow in the panel was kept ON. The amber lights were flashing outside, but inside the car it wasnt showing so.
Then I just inpluged the SC-II and everything was back to normal.
Whats happening?? Help!
Cadu
Nissan Frontier `08 SEL A/T
PAE-BRA
Old 09-16-2008, 10:43 PM
roastbeef's Avatar
hmmm... the "tick tack, tick tack" of the blinker is actually the relay oscilating which causes the blinking. im sort of baffled that the ambers were cycling even though it seems that they should be constantly on by the symptoms you described. unless someone has another explanation. sorry, i can't help.
Old 09-17-2008, 12:04 AM
cvianna's Avatar
hi roastbeef!
Actually, the tic tac in the 08 is electronic. There is no relay, its an solid-state blinker, so they installed an speaker that makes the tic-tac...
Its some sort of electronic malfunction. Maybe im missing something.
thanks anyway !
Cadu
PAE-BRA
Old 09-17-2008, 12:06 AM
Pro2X's Avatar
wow...hope you figure it out...I wanted one but now im kinda scarred...This is the only one I heard of doing this though fwiw
1 day, Pro2x will be completed...
Performance: nismo cai, tbs, ims, ground kit, coolant bypass mod, optima yellow top, d. thorley headers, all 4 cats removed, magnaflow muffler, and new piping
Exterior: tinted windows, black billet grill, colormatched headlights, fiberglass bed cover
Interior: pathfinder switch mod, katskin 2 tone leather, KW-AVX706 dvd/cd, Sundown 1500d, JL 300.4, JL12w6v2, Polk Audio Momo 6.5 comp/6.5 coaxials
Suspension: cst 4" spindles,prg 3" spacers, Alcan 8 leaf pack, extended saw shocks, extended ss brake lines
Wheels/Tires: pro comp 7189's with nitto tg 295/75/16
Offroad: m226 swap, titan alum diff cover, mag hytec seal, ac diff skid
I will support Barack Obama as much as everyone supported George W. Bush!
Old 09-17-2008, 12:35 AM
jpaddy's Avatar
Hmm, I just got my scangauge two weeks ago, plugged it in and ran the set up exactly like the instructions prompted and viola! works like a charm, even setting up an x-gauge for horsepower was easy. I haven't seen any weird goings on but I will keep my eyes open. You can go to cleanmpg.com and check things out there, they wield the scangauge there like a ninja uses throwing stars, I am sure they can help you out.
Old 09-17-2008, 01:09 AM
What does customer service from scan gauge say?
Old 09-17-2008, 04:57 AM
roastbeef's Avatar
a speaker makes the clicking sound? hahahahaha
Old 09-17-2008, 10:27 AM
shift_this's Avatar
my 06 didnt have an electronic blinker. when i put my LED bulbs in, they blinkers went real fast. thus, it was not electronic. they may have changed them in newer models....i dont know
Old 09-17-2008, 08:46 PM
Blue22's Avatar
My scan gauge works like a treat simple plug and play. I too have set up several x gauges and they work perfectly. You may try changing the protocol that the SGII uses to communicate with your car, but a simple full reset of the SGII would be the first thing I'd be doing though. Failing this I'd be contacting customer support for some advice.
2008 ST-X 4x2 V6 A5 Opal Blue;
22x9.5in Chrome Advanti Sabotages with 285/35/22 Nexen Roadian HPs, Street Legal Tint, Hard Cover, Scan Gauge II, Chrome door handle covers & tailgate cover, tinted bonnet protector & wind deflectors.
Lowered 2" front on superlow king springs, 2.5" rear with reset leafs and short body Oztec shocks and shaved bumpstops.
Old 09-17-2008, 10:50 PM
I had a similar problem with the instrument panel indicator lights (brake, slip, dash back light, etc) cycling on/off individually and without a noticeable pattern. Also, the tachometer function would drop in & out.
This was on the first unit I received, like a day after I received it and it happened on morning startup. After searching the net, I did find a few (maybe 2 or 3) similar occurrences by others but this looks to be very rare. I contacted the seller/vender and he immediately shipped another unit and I've never had a problem since.
I'd say disconnect the unit and contact the vendor ASAP.
Note, the service & support I received was excellent.
Gifford Automotive Home
ScanGuage - Nissan Frontier / Navara Forum
The Following User Says Thank You to bentt For This Useful Post:
tdm88 (10-05-2008)
