Rotors? - Nissan Frontier / Navara Forum
Old 12-05-2012, 09:23 AM
Rotors?
Took my truck in for oil change and dealer said the front rotors are glazed but pads are still ok, steering however is fine, $200 for resurface or $500 for new plus pads. Are these easy to replace that a friend who knows a little can do it? I'm sure I'll save hundreds, thanks.
Old 12-05-2012, 09:36 AM
bonestock's Avatar
Diy!
There are things that eat at a man worse than dying.
Old 12-05-2012, 09:45 AM
I searched the forum for DIY thread, can't find it. Link please.
Old 12-05-2012, 09:57 AM
upflying's Avatar
That dealer is a stealer. Oil changes at dealerships are an opportunity for the lube dude to look around your truck to find high profit, unnecessary repairs. I am elated that you declined the dealer offer to get a second opinion from us. Lube dude is under pressure from management to up the profit on oil changes. Lube dude gets a spiff if they sold you on the glazed rotor BS.
Glazed rotors are normal and nothing to worry about.
I have not yet pulled the wheels on my truck but disc brake repair is usually the same on most vehicles.
1. Remove wheel
2. Remove caliper
3. Remove rotor from hub
Reinstall in reverse.
2010 Frontier Crew Cab SE long bed 4X2, avalanche
1986 Chevrolet Monte Carlo SS, stock
Old 12-05-2012, 09:58 AM
Pretty much the same for most vehicles. Take off the wheel, Disconnect the calipers and remove the rotors. Some can be harder than others to get off. I had an elantra that required beating with a sledge until the rotor broke. Not a difficult job. Hit the bolts with some PB blaster the day before just to loosen them up.
2011 Frontier SV 4x4 Long Bed
2" spacer
Adjustable shackle at 1"
Old 12-05-2012, 09:59 AM
HightecRednec's Avatar
Feedback Score: 6 reviews
First off... Definitely DIY.
Second... I had all four of my rotors resurfaced for $25 per rotor so, $200 sounds crazy to me.
2007 CC LE 2wd
Mods
-Volant CAI - Superchips Tuned - XTP IMS - 2" Daystar Spacers - Old Man Emu Medium Duty Leaf Packs - 32" General Grabber AT2s - Extang Trifecta - Xoskel Bumper Mouth Bracket - Rigid Industries LEDs (x4) - Morimoto Mini H1 Projector Retrofit
Great people supporting a great cause - Products for Good
Originally Posted by MarcDef View Post
I have the same truck as you and am experiencing acceptable blowing.
Old 12-05-2012, 10:31 AM
Take the rotors off as mentioned above, take said rotors tks a parts store that can turn them, reinstall with new pads, stop going to dealerships.
www.nissanwheelers.com
JUST FRIGGIN BY-PASS!!
Old 12-05-2012, 12:34 PM
Yeah everytime I get oil change there's always something. I'll have my friend takes care of them for very minimal fee. Just want to make sure they're not hard repair. So far I don't even hear any squeak.
Old 12-05-2012, 01:36 PM
olddognutrx's Avatar
The dealer was hosing you!! If your rotors are glazed the pads are no good anymore and you never resurface or replace a rotor without replacing the pads. Question is, were you having any problems with the brakes prior to being told you had glazed rotors? As far as replacing or surfacing the rotors, you not only have to remove the calipers but also the caliper mounting bracket to remove the rotor and from experience I'll tell you that the bolts holding the bracket will not come off easy.
If you did actually glaze your rotors your braking way to hard or carrying heavy loads.
2012 SV 4X4 Auto.
CC Short Bed
Bullydog GT
Air Box Mod
K&N Drop in
TB Heater Bypass
Front Bilstein 5100 2" Lift/Stock Springs
Rear Calmini 1.5" Shackles/Bilstein 5125
Old 12-05-2012, 03:09 PM
Truth^^^ forgot all about the caliper mounts. 19mm if I remember correctly?
